Best 2.4Ghz Transmitter with Speed function
Hi guys I've tried looking for previous posts on this but had no luck finding it.
Im looking to get a new transmitter for my HPI sprint 2 sport which I have a Traxxas Velineon vxl 3s system installed on. * not sure if that makes a difference in which transmitter might be compatible nut just that you guys know
Like i said in the title im looking for a transmitter which as good useful features, good back light, displays my car speed... btw I have seen the TQ which is iphone/ipod touch compatible but i dont own one so thats out of the equation for me. price is not an issue
Could you guys tell me the 5 best ones available or you would highly recommend please, I would really appreciate that and thanks in advance
Telemetry radios generally monitor temperature, not speed. The Traxxas TQi with the Ipod attached and the proper sensor installed is the only one I know of that will do it but even then, it is only programmed to do so on some Traxxas cars.
Oh wow that sucks
The Airtronics MT4 comes with an RPM sensor that will allow you to display speed with some gyrations. There are also aftermarket sensors that are more easily integrated. I have this radio and like it very much.
I believe that Spektrum (which IME is crap but plenty of other people like) also has a new mid-line radio with telemetry, but I wouldn't buy it on a bet my Spektrum gear sucks so bad. Glitchy shite that belongs at the bottom of a lake.
radio
A speed gun works better for speed. I have radiopost, because it is for me the most hooked in feel to what the car is doing. Now that Grid RC has a drop down wheel for the MT4 I might try that again, but wasn't comfortable to me after having a drop down wheel on all my 3pk's
The Futaba 4PLS has telemetry(4PL doesn't)and covers temp, rpm, rx voltage, external voltage, plus atmospheric pressure and GPS for flight systems. I just bought one and love it so far.
http://www.futaba-rc.com/accessories/futm0850.html
Thnx guys ill take a look at the Futaba... @btrukr i got a speed gun but was hoping there was a transmitter that had a built in speed detector
Lots of radios are equipped with speed (and other) telemetry these days. The Aitronics MT-4 and M12, the Futaba 4PLS, and the Spektrum DX4S, DX3R, and DX3S, and Traxxas TQi all have it. If you want to go old-school, the Nomadio has been doing telemetry since 2004 (I still have a Nomadio Sensor and a couple of Nomadio Reacts).
I recommend the MT-4 or 4PLS for reliable all around radios or the M12 if you are a hardcore racer (I currently use the M12 and MT-4).
@guidoracer i know the traxxas tqi has the ability to track your top speed except it is iphone compatible only which i dont have, but im reading the others and they dont seem to have it.. i Looked t the 4pls and MT-4 there is throttle speed, acellerastion speed, sterring speed and rpm... But not top speed
With respect to top speed, you need to tell the radio how far the car travels per each revolution of whatever thing you're monitoring the RPM of (could be motor, could be spur, could be shaft, whatever...). Then the radio does the conversion to speed. Download the manual and look at pages 69-70.
A speed gun will still be more accurate than any of the RPM-based ones because the RPM based ones don't account for tires ballooning at full speed which can change the final drive ratio (even if the ballooning is very slight) which effects how that speed is calculated.
Yeah, the only way you're going to get a radio that displays accurate top speed is with GPS. I'm pretty sure you'll only get that with flight systems with this sensor. The sensor costs $180 and the radio is $3000.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBYNR
oh ok i got it, so my hopes of finding a radio with that feature which is accurate is pretty much zero.... im just surprise no one has not made one with that feature will all the high technological access these days. thnx for the input guys, very much appreciated
