Cheap motor from Hobbyking?
Hi, I'm looking for a cheap 1/8 BL motor from HK for Losi 8ight buggy.
I'm holiday racer, no hard bashing or big power need.
I like this motor http://www.hobbyking.com/hobbyking/s...dProduct=31080. What's your opinion? Someone with experiences with this motor?
Thanks for help.
Thanks for help.
I was looking at that motor myself for a GT8 (1/8 scale onroad buggy). I currently have a trackstar 2650kv (sensorless) and so far its been fine. I like that the 2350 is sensored and can run up to 5s (if you wanted highspeed runs or just the higher efficiency with higher voltage)
edit: Here's the motor I currently have.
http://www.hobbyking.com/hobbyking/s...rSearch=2650kv
This is the one you want:
http://www.hobbyking.com/hobbyking/s...or_1900KV.html
I've been racing with this motor for a few months now, and it has gotten me to quite a few podiums. I really like the power, it's just there @ every rpm. Very smooth as well. My esc has punch that goes all the way to level 9, and right now i'm @ 4. Very impressed and at less than half the cost of other "bigger brands".
Thanks for help.
Thanks for help.
Uh....2650Kv on 4s is way too much. Insane power, but not controllable in a track setting. Not to mention unwanted heat and smaller gearing range available. Ask anyone @ your local track, and they'll tell 1900Kv is plenty for any situation. Lower Kv = more torque, less speed, higher Kv = more speed and less torque. 2650Kv on 3s would be a good setup as well.
Please share the ESC you paired with this motor.
Thanks!
Thanks!
