Official FlySky FS-GT3C thread
#166
I want to bump this thread and see if anyone else has had the same luck that billdelong has had with getting the FS-GT3C to work with Vrc Pro via USB (Without their adapter)?
I did everything he said and am not having any luck getting the transmitter to calibrate properly, the signal seems to be really jumpy and unable to calibrate.
Any help is much appreciated.
#167
#168
IF things were working fine or as normal, after using it for the long term racing, does anyone have a problem with it. What I mean is, after long term using in racing at the club level, does anyone's experience shows that it's not good enough for racing at club or even on higher level?
I am not a hater, in fact I used to love them, but I can no longer trust these units.
#169
Hello,
I have a FlySky FS-A6 6 channel receiver, it came with FlySky FS-i4X transmitter.
Is it possible to use FS-A6 receiver with gt3c?
Thanks.
Thanks.
#170
Flysky gt3c problems please help
I have had this controller for a few years now and have not been able to use it because Off the power button issue I've been through and fixed the issue now I have a new PROBLEM i have plugged in the receiver and basic settings are done on control MY PROBLEM IS THAT THE THROTTLE IS MY STEERING WHEEL AND MY STEERING IS MY THROTTLE TRIGGER PLEASE HELP
#171
I didn't see a GT5 thread.
I bought the Turnigy GT5 from HobbyKing. I also bought FS-A3 receivers and they will not bind? Any ideas why?
#173
I put the bind plug in the last/4th port, turn on the ESC and ensure the red light is blinking quickly. I then hold the bind button on the transmitter and then power it on. The transmitter says Bind in definitely. It doesn't go off until I cancel it or turn the transmitter off. There is an odd, partial bind going on though. At some point, usually fairly quickly, the receiver will start blinking slowly, but the transmitter still says Bind. I cycle both the transmitter and ESC and the radio controls the truck for 10 seconds or so before it loses the bind and stops working indefinitely.
#174
The FlySky manual lists the A3 as being compatible. I do have the Turnigy radio, but that shouldn't matter. We have to figure this out or, in my opinion, this radio isn't worth having.
#176
Reciever
I have the GT3C and have had 2 recievers dump channel 2 after programming my esc. One was a speed passion revention s and the other is a trackstar 80A turbo. If i change the esc to channel 1 i have esc control through the steering wheel and the servo plugged into channel 2 is dead. If i put the servo into 1 like normal and the esc into 2 i have servo control but no throttle/brakes. Maybe i've reconnected the esc into the reciever backwards? My revention s had the small tang so you couldn't do that but the trackstar doesn't have that tang. I lost the channel 2 on an fs-gr3e and i think the other one was an fs-gr3c. I've ordered some fs-gr3f's this time.
#177
Anyone still using these, How are they for beginner racing?
#179
hi new to the forum but have a question for anyone that can help.... i have one of these tx's and 5 rx's but im trying to add a 2 speed shift on my rr10 but when i install the servo on channel 3 the rx goes into bind mode... please help before i throw this thing out the window lol
#180
I got the flysky pc adapter but i wanna keep it not cut for my drone sim's. i do have an extra connector though. Is there any reason i couldnt cut that in half so i can leave the 3.5mm dsc? the wires in the adapter are red and a braided strand, sure its the same as the yellow... Any thoughts or anyone tried this?
