Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-17-2013, 10:12 PM   #16
TOM MAR's Avatar
You got a part number? I have to go now, but I would like to make some inquiries tomorrow.
Tom
TOM MAR is offline   Reply With Quote
Old 04-18-2013, 12:11 AM   #17
hayabusafmw's Avatar
can't seem to find one of the box but it's
RC CAR LED SYSTEM II
bought it at hobby partz
i think it's this one 41P-LED-LightKit
www.rcprofile.com
hayabusafmw is offline   Reply With Quote
Old 04-18-2013, 03:53 PM   #18
im about to pull it out and use it in a other vehicule minus the ''blinkers''
kinda disapointed that i had drilled holes for that
the instructions i have are IDENTICAL to that
http://www.ebay.ca/itm/RC-Car-truck-...#ht_4457wt_908
and they aren't gt power... even though its the same exact pictures and such
www.rcprofile.com
Old 04-18-2013, 05:52 PM   #19
TOM MAR's Avatar
Sounds like you may have gotten a bad one. There seems to be a 30 day limited warranty & there is always this
Customer Service & Tech Support from HobbyPartz.com, at RCDiscuss.com
It could be a bad solder connection, bad plug or many other things. Reading up most seem to work well & can be rather sensitive & the ones with problems do all kind of things.
Keep us posted on this, they are currently out of stock, so I will have to wait to order one.
Tom
Old 04-18-2013, 06:15 PM   #20
Contacted hobbypartz chat.....
they told me to re-ship it to them and they would replace - refund them
that would cost me the actual price of the item... what a waste
I want to know something
I managed to make everything to my liking... it's pretty weird
I have a hs5646wp waterproof hi voltage servo (no bec installed maybe thats the problem dunno)
The only way i could do it it's like this
TRIM L 92
SUBTRIM L 20
epa L 110
EPA R 67
..... something isn't centered and it's very bad maybe even the servo maybe?
thats not right....
dunno but hell i have full throw still and thats not normal if you ask me normally with trims up like that no way i can do anything like that
I tried with a other remote & receiver it did the same thing...
and my second led unit is the same same problem or ''similar'' all on the right side weird ill try it on a other servo just for the hell of it
www.rcprofile.com
Old 04-18-2013, 06:54 PM   #21
TOM MAR's Avatar
" (no bec installed maybe thats the problem dunno) "
Ya know I wondered about voltage today. A fully charged 2 cell lipo is around 8.4 volts, there is a 6 volt max. It would have too That is most likely the culprit. Can you try it with a bec set between 4.8 & 6 volts
Old 04-18-2013, 07:21 PM   #22
I was testing this on a 5000 mah 2s 60c gens ace fully charged
I dunno if it's enough to power the led , servo , esc , motor , and winch (which is never on anyways just idling)
www.rcprofile.com
Old 04-18-2013, 08:03 PM   #23
TOM MAR's Avatar
It is most definitely. Even at its critical low voltage after discharge is too high.
Old 04-18-2013, 10:49 PM   #24
THanks TOM MAR for helping me
I think i found a solution tonight
let me know what you think
Since centering a servo horn perfectly 90 degrees and having both wheels straight is almost humainly impossible this is why we have SUB TRIM and TRIMS
I decided to put the wheels purposely more on the left side and it made sens cause the horn was almost 90degress
thought the wheel were very off center i went and put 87 subtrim which is very high but considering i didn't put any TRIMS this shouldn't affect full throw
and so far problem solved!
www.rcprofile.com
Old 04-19-2013, 01:21 AM   #25
TOM MAR's Avatar
Hey, as long as it works. Yes that's why we have them.
Good work & good luck.
YW Tom
