Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-14-2013, 12:32 AM   #1
howieberry's Avatar
Exclamation cc mamba max and cc 5700kv help.
Here is a link to my video. Need help on what the problem is. I tried everything to try to fix it but it still dose it.
https://www.youtube.com/watch?v=r7Cb...e_gdata_player
the person with the lowest feedback ships first
axial yeti, traxxas summit, t2m( old french nitro 2wd stadium truck), losi xxt.
howieberry is offline   Reply With Quote
Old 04-15-2013, 07:50 PM   #2
howieberry's Avatar
Help anyone?
Old 04-15-2013, 08:31 PM   #3
hotrod87's Avatar
Trader Rating: 252 (100%+)
Is the esc set for brushed ? Did the motor get wet or hot ? May have smoked part of the stator ? Do you have another motor or esc to try ?
ON A WALKABOUT AS OF 7/27/17
hotrod87 is offline   Reply With Quote
Old 04-15-2013, 08:33 PM   #4
TOM MAR's Avatar
Is it new or have you had it for a while ? Did it work before for you?
TOM MAR is offline   Reply With Quote
Old 04-16-2013, 02:01 PM   #5
howieberry's Avatar
It worked great till one day it just decided to start doing that. It never got wet or hot. I have had it for about a month. I got it in a trade along with a sidewinder that dosnt work.
Old 04-16-2013, 06:32 PM   #6
hotrod87's Avatar
Do you have a brushed motor you could try ?
Old 04-16-2013, 08:29 PM   #7
howieberry's Avatar
That I do not. I have another motor on the way tho. I beleave it's the wires from the esc to the reciever. The one has a bunch of nicks in it but the wires are attached. I thing there caroaded so it is loosing signal from the reciever. I'll let you know if it's the motor once the other comes
Old 04-21-2013, 08:14 AM   #8
howieberry's Avatar
Well it is not the motor. Going to try soldering a new wire from esc to reciever. Wish me luck
Old 04-23-2013, 08:06 PM   #9
howieberry's Avatar
Fixed it!! It was the wire from the esc to reciever
Old 04-23-2013, 08:28 PM   #10
stunter38's Avatar
Trader Rating: 73 (100%+)
i was going to suggest the reciever wire .
TLR VIPER ELECTRONICS
LOWEST FEEDBACK SHIPS FIRST
stunter38 is offline   Reply With Quote
