Can a MMP run a Tekin Pro4?
I've got both ad well. Go with the rx8. Tekin all the way.
I first tried a MMP in my SCT410 with a PRO4 4000kv and it didn't feel like it had enough power. I swapped it for an RX8 which helped.
Why would you need an external BEC? I've never had an issue. I've noticed a ton of people on this forum have very strong opinions based on no facts what so ever. Usually younger people that read more forum BS than actually understanding it.
The max amp manual says 4.5 550 limit. Should be good to go. I am using a 5 turn with mine and no problem, it is 4120 kv. All that being said this is a 70 amp system using 13 gauge wires.
I think using a bec usually involves a servo?
I disagree on this. The Rx8 isn't smoother I have both of them with a T8 motor on two 1/8 buggies and the MMP is smoother for a simple reason: it draws less amps. Notice I use an external BEC with both of them.
