Want to upgrade to a better battery charger.
#17
I agree it's wise to get more than 50W of charge power. I suggest considering advanced capability also.
Better chargers have greater balancing power, can measure the Internal Resistance to help keep tabs on battery condition-performance, control state of charge for quicker charges if running mod which also helps lipo life, control final voltage, higher discharge power for the occasional times it's needed, etc.
Better chargers with more sophistcated features include Powerlabs, Net & Duo Hyperions, ThunderPower, and iCharger models.
#20
Other thing I like they are smaller in size.
#21
Two power sources in series adds voltage, amperage is the same.
Two power sources in parallel adds amperage, voltage is the same.
Special precautions and/or appropriate supplies are required either way.
#22
In a series connection all of the current must pass through each unit. And since each can only pass 47 amps that's all the series combination can pass.
#23
I use the Icharger 206B. does 20 amps up to 6s. Got mine when the LHS was open, they were a Progressive RC dealer. The charger is small, doesnt get hot, and charges quickly. Has all the bells and whistles too. IR, Motor Drive (if still running brushed motors) storage mode, balance charge, non-balance charge, lipo, lilo, nimh, nicd, does it all...
It is DC powered only. I still use my Radio Shack 25 amp power supply on 2 of these.. no issues. I charge my batteries, at high rates, because I dont have time to sit at my table. Im also running the track, so I have them on balance charge, in a lipo bag. One charges at 16 amps, the other at 7 amps. Usually they get done in 15min or less.
Progressive RC
Progressive RC
#24
Can't say I care for the way many achieve the 24 volts with series server supplies though, leaving one case ungrounded. Some take the care to modify the supply for floating DC outputs, that is a better and safer solution I believe.
#25
I have the Junsi iCharger 306b which charges up to 30A single port up to 6S. It has been my best purchase in RC! At 24V input it's a 1000W charger and at 12V input it's a 500W charger. I use the TrakPower 25A 12V because of its size and don't need more than 300W. I charge my 2S 6600mAh Turnigy NanoTechs at 30A which finish in less than 10 minutes even mostly discharged which comes in handy during outdoor with 4wd Short Course. I highly recommend it.
http://www.progressiverc.com/icharge...Fcme4Aod60YA4A
#26
If the charger can accept the 24 volt input (which your PL can) series is correct. Where possible higher voltage is more efficient, less heat and power loss at lower current.
#27
I will second either the iCharger 206b or 306b. The 206b with only a 350-370w power supply will charge a 4s battery at 20a. It's not entirely necessary to go to the 306b unless you want to try and hit your battery's charge rating if they're high. You won't need more than a 550w PS for the 306b and a 370w PS for the 206b if you don't go over 4s.
I'm a fan of progressive rc. I bought one of their powerlab 8 case combos and it's been great so far. Overall i'd recommend http://www.progressiverc.com/the-sid...50w-combo.html.
It's important to note you might not get a charger's full capability if you don't match the required input voltage. For example the iCharger 206b's 500w rating only comes in at > 18v input. Again.. with 4s batteries you'll only need a little over 350w.
Progressive RC's power supplies have adjustable voltage which you won't find on many (if any) converted server PSUs.
#28
The supplies I bought from ebay stated that they are wired specifically for series operation and the cases can be mounted side by side, touching each other. So, that was the first thing I did when plugging them in. So I permanently attached them and did a wrap that looks like carbon fiber and some decals. http://i883.photobucket.com/albums/a...psc204eb38.jpg
