Tekin RS Gen 2
#1276
https://shop.stormerhobbies.com/product-p/tektt3825.htm
#1277
No. I removed the fan months ago after noticing an increase in ESC temperature. Only things plugged into the receiver are the servo, ESC and transponder. I unplugged the servo and transponder to see if that had any affect. The ESC still showed an increase in temperature while at "idle".
#1279
#1281
A picture says a thousand words.... Thanks YZ. Now when you plug the hotwire into the reciever wire that let's you make all the fine tuning to the speed control.
And when you plug into the data port that let's have access to data logging and what else?
Also I didn't get her an adaptor wire in my hotwire. Does it come with speed control maybe?
#1282
Team Tekin
The adapter wire would normally come with the ESC.
#1284
yes..
#1286
There are replacement pins and pliers you can buy from your local hobby shop.
#1287
Esc
What can the problem be?
#1290
So I got the plug fixed, plugged it back into the receiver, hooked up a battery, turned the ESC on, I have steering but no throttle, and the chime when calibrating or setting up is very very low. All wires are fine, fully charged battery, LED's are the way they should be.
Tekin - ESC LED Error Codes
