vxl-3s & lipo Help please!
i have a rustler vxl-3s with a venom lipo 7.4v 2 cell 5000 25c battery and just geared 31 pinion/76 spure that im having problems running it? when i give it throttle it takes off for a second then green light on ESC starts flashing red which mean low battery/ voltage correct? my next question is are thoughs gears to high? also whats the right way to charge my lipo? right now ive been charging on 5.0A, lipo 2, fast charge.. Someone please help/give me advise on what to do! thanks
Did you temp the battery after running it? That's a low amp battery that you're putting a high demand on considering your motor and gearing and getting big voltage drops where it's hitting lvc. Get yourself a higher C lipo...at least 40 on a 5A battery. The lipo you have now only puts out 125A constant. Not enough.
the lipo is about 2 weeks old and yes the low voltage cut off is on. how long does it normally take for a lipo to charge? should i discharge then charge or just charge every time?
what gears should i go with right now for it not to harm the lipo
ok i went back to stock gears 28/83 lipo fully charged. if i lift the back wheels off the ground and spin the tires full throttle Green light on ESC stays green. when i put it on the ground it takes off for about a secound and starts flashing red light slowly?? yes i charge on Lipo 2 cell, 1c (5.0A) the only thing is that it only gives me the option to fast charge.
