FlySky FS iT4 Transmitter Thread
#436
cn-us
See a few posts above: http://www.rctech.net/forum/12930601-post220.html
Basically leave a message stating your problem and then they will email you. There is no direct download for the firmware on their site.
If you look at my profile one of my visitor messages has the link to download firmware version 1.02-US.
Mike
Mike
#438
Here is the email I used.
[email protected]
After the chip swap mine is working great. Wonder how long until the new stock is out there?
Buzz.
[email protected]
Buzz.
#439
[email protected]
Buzz.
[email protected]
Buzz.
#440
Should be a little faster if Jerry has caught up on all of the request for the chip.
Buzz.
Buzz.
#441
Hi guys anyone know if this "latest 2nd gen" version is the one with the updated chip? I need to buy the tx but don't have the skills to solder...
http://www.ebay.com/itm/Latest-FLYSK...item1c3612812e
#442
Best you might be able to do is ask them to tell you the info from the radio. Then ask Jerry if he can tell you the build date and see if it has the new chip.
You could ask them the same thing about this radio. Ask for a serial number, then ask Jerry if he can tell you the build date?
Buzz.
http://www.hobbypartz.com/79p-it4-to...-titanium.html
Buzz.
#443
The recievers are not as cheap as the 3gtb receivers. But they are around 16-20$ I bought 3 from eBay shipped for 44$. However I was disappointed with end results. You have to bind each receiver every time you use it. Unlike the 3gtb you can power on and go
#444
Anyone know if there is a FlySky surface radio that supports 433mhz operation? I'm working on a project that will need more range that a typical radio provides. I am finding a lot of stick radios that can do it, but no pistol grip stuff.
#445
I just bought the fs-it4 but haven't had much time to play with it, however I also bought 3 xtra receivers. The biggest complaint I have is I mounted 4 receivers in 4 cars and I have to bind each receiver every time unlike the 3gtb. Other than that I haven't played with it enough. The sensors will not recognize on my controller but I don't really care about using them
#446
#447
FYI - I asked jerry about ETA for new it4s with upgraded chips/firmware- his reply:
Very glad you are interested in our iT4.
About two or three weeks later you can buy latest it4 in Hobbypartz or ebay.
Best Regards,
JY
skype: jerry_flysky
TEL: 086-1866 5882 728
SHENZHEN COLCO INDUST DEVELOPMENT CO. LTD.
FLYSKY RC MODEL Co.,Ltd
Best Regards,
JY
skype: jerry_flysky
#448
Quite interesting. The Flysky iT4 and Absima CR4T share the same electronics and I suppose that Flysky makes the radios for Absima. Why then the Absima has the multiple rx binding issue allready fixed (from the start of the year), while the Flysky says "About two or three weeks later you can buy latest it4...". Need to empty the stock?
#449
Thanks Littlebuddha, I will be ordering 2 set of the iT4 with the upgraded chips and firmware + 6 Rx's when in stock from HobbyPartz.
