What do you think about Futaba BLS156HV ?
I'm looking a new servo for my 1/8. I like the futaba bls156hv. What do you think about this model ?
FEATURES:
•Equipped with a Brushless motor that lasts longer and operates at a lower temperature than Brushed motors
•At least five times longer lasting than brushed servos
•Dual ball bearings and Samarium cobalt magnets
•Smoother operation and greater resistance to jolts and vibration
•High Voltage
•Standard size
SPECS:
Torque: 7.4V: 21.0 kg.cm; 6.0V: 18.0Kg.cm
Speed: 7.4V: 0.12 sec/60 degree; 6.0V: 0.15 sec/60 degree
Size: 40 X 20 X 36.8 mm
Weight: 60g
tkz for your replies
FEATURES:
•High Voltage
•Standard size
SPECS:
Weight: 60g
any reply ?
very good servos for throttle and steering
I have two in my Truggy Mugen and work very well. The use with Lipo.
Best Regards.
Best Regards.
I have them in my nitro buggy & E-buggy and I love them!!
SPECS: Speed: 0.15 sec/60° at 6.0V
0.12 sec/60° at 7.4V
Torque: 250oz/in (18.0kg/cm) at 6.0V
291.7oz/in (21.0kg/cm) at 7.4V
Size: 1.57 x 0.79 x 1.45" (40 x 20 x 36.8mm)
Weight: 2.33oz (66g)
Power Supply: DC 6.0 - 7.4V
Horn Screw Size: 3x8mm
tkz
tkz
It is an AWESOME servo!
I figured I’d post this question in this thread since it’s somewhat relevant. Does anyone have any experience with the BLS175HV servo? It has identical specs to the BLS156HV mentioned in this thread earlier with one exception, the BLS175HV has the S-Bus feature. I understand the S-Bus feature is really intended for Air applications. The reason I’m asking is that Amain has a special right now for the BLS175HV servo @ $119.99 (reduced from $159.99).
After a little searching, it looks like the BLS175HV has been discontinued which could be the reason for the reduced price. Regardless, $119 for a Futaba brushless HV servo with some solid specs seems to be a pretty good deal. I’d just like to hear if anyone has firsthand feedback on this specific servo in a 1/8 off road steering or throttle/brake application.
Futaba BLS175HV Brushless S.Bus Programmable High-Torque Digital High Voltage Servo
Futaba BLS156HV Digital Brushless High Voltage Servo
