Please Help! Don't want to burn my house down! >
Old 01-13-2013, 10:11 PM
  #16
Status update:
I switched the 2 outer wires on the connectors checked the voltage and everything seems good. I was able to solder the broken copper band on the balance board(ghetto rigged temporarily, new one on the way), plugged everything into the charger, set it on Lipo Balance and everything works great. The charger displays the voltage of both cells and they are balancing correctly.
Both battery and board stay completely cool to the touch, everything is working great.
Thanks again for everyone's help!!!
joe226 is offline
Old 01-14-2013, 04:47 AM
  #17
R/C Tech Elite Member
EricW's Avatar
Originally Posted by Theibault
Why are you trolling this thread? This is a helpfull forum. No need for name calling and irritating others. Just move along. PS, you need to educate yourself with some manners.
Uh, I'm not trolling anyone. All I'm saying is you get what you pay for in this hobby.
EricW is offline
Old 01-14-2013, 08:07 AM
  #18
Integra's Avatar
Theibault was talking to Johnnysplits, Not you.
Integra is offline
Old 01-14-2013, 08:57 AM
  #19
huzzler's Avatar
Originally Posted by joe226
Status update:
You can eliminate the battery board all together. Just plug the balance tap into where the balance board plugs in. Just make sure the black wire is all the way to the right. That's how I run my charger works fine.
huzzler is offline
Old 01-14-2013, 10:29 AM
  #20
This also means that if the OP ever reverses a plug again, he'll burn up a trace on the charger's board instead of the balance board.
Keep using the balance board. It'll burn up before the charger does.
WindDrake is offline
Old 01-14-2013, 10:34 AM
  #21
EricW's Avatar
Again, that depends on the charger. I've plugged my balance board in backwards to my Prodigy Duo 620 and it gave me an error. Nothing went up in smoke. Also, you can plug your balance board in backwards just as easily.
EricW is offline
Old 01-14-2013, 10:35 AM
  #22
EricW's Avatar
This is a good suggestion, I bought two of these last week for my charger. I no longer have to tangle with a balance board.
http://www.amainhobbies.com/product_...let-Connectors
EricW is offline
Old 01-14-2013, 11:27 AM
  #23
huzzler's Avatar
Yeah I never use balance boards. Doesn't matter if you plug it in backwards charger will detect if it's plugged in backwards.
huzzler is offline
