novak help
novak help
http://www.amainhobbies.com/product_...er-Connector-5
will this work on a novak gbt2 lp esc for the motor its a 8.5 turn. if not what size i get?
2mm seems pretty small (about the size of the balance port plug on a battery with tubes). I used a 4 mm Castle connector for my motor wires.
http://www.amainhobbies.com/product_...-Connector-Set
Solder direct to the motor tabs. Skip the connectors.
On the Novak ESC's that come with bullet connectors for the motor, I believe they use the 3.5mm ones. Here's the set:
http://www.amainhobbies.com/product_...ector-Wire-Set
Do not use the 4mm birdcage connectors, they are very hit and miss with folks and some of them have more resistance to them and they get hot as you draw current through them.
If it is an option for you then just do a direct solder to the ESC, no muss, no fuss... but I know that does not work in every playbook out there.
Any (battery and motor) connectors, wires or solder joints you have should get a baseline with the first few runs at least. If something is getting hot, address it... if you are using good connectors then more than likely you have a solder issue going on.
