novak gtb2 esc
novak gtb2 esc
how are they and is there no timeing in them to?
They are great ESC's. I use one in my VTA car. I had been using the edge and was just not as fast as some of the guys using the gtb2. They do not have any timing adjustments at all. That's why they can be used for VTA. They do have a bunch of other settings to change which make it a super smooth ESC.
i can go as low as a 3.5 right?
Wrong info... deleted
the one in my sc 10 4x4 has no timeing in at all its the sportman
6.5 is the low i will go in a 22 sc kit
Deja is right once again!,
You can program minimum brake,drag brake,minimum drive, throttle curve and brake end point.
just got one from the lhs thanks
can i use a bec with it thanks
http://www.amainhobbies.com/product_...less-Motor-65T
will this be ok with it
