How do you wire a MMP to Tekin T8
I am ready to solder the three motor wires from my Mamba Max Pro to my sensored T8 tekin 1900kv.
The Castle instructions say hook it up and if it runs backwards just reverse the wires. I wanted to try and solder 1 time and be done.
Does anyone have a pic of how the wires from the esc to the Tekin T8 go?
The Tekin T8 has A , B , C The MMP has red,black,white
Thanks in advance.
Thanks in advance.
Id be careful using a T8 on an MMP...Im sure they all vary for the T8 1900KV has a max amp draw of 125A. If Im not mistaken the MMP has a maximum amp rating of 100As.
A lot of people at my local tracks use the t8 1900/mmp combo for 1/8 buggy. One of the top drivers in this area has been using this combo for 2 years with no problem. I just find the rx8 to be unreliable. I just spent 94.00 to get one repaired by Tekin. I am thinking about selling it when it comes back and get another mmp.
I find it way more reliable than RX8 and MM...... plus its a few ounces lighter as well
Hey guys im getin into 1/8 from 1/10 and so i already have a mmp but the 8th motar wires are bigger do i gotta cut wire off one of em or can i solder the wires together ? And what motars can i use with mmp? Thanks in advance guys!
Tekin T8 1900 kv works really good with MMP,all you have to do is cut off the end where the original plugs are and solder them to the motor or you can get a bigger plugs if you are using MM motor.
I've been running a mmp/Tekin 1900kv combo in my Slash 4X4 with 3s for about a year with no problems. I've been thinking of trying this combo in my 1/8 buggy, which I'm currently running a MMM/2200kv combo. I've tried the MMM/Tekin 1900 kv, but the Tekin sensored motor does not like to be run sensorless. The motor was cogging real bad with a the sensorless MMM esc.
