Novak gtb2 issues
Novak gtb2 issues
I'm running my Sakura zero s with a Novak gtb2 with 17.5 ballistic using a spectrum dx3s and every once in a while the esc will stop working and the red and yellow lights will blink. What does that light combo mean? It's not in te paper work that came with it.
Matthew
Edit: I worked out that that is the lipo cut off( using Nimh right now) but I have very poor braking. How do I set it up?
Matthew
Anyone? I still have zero brakes???????
yes i think so. I have now backed them down to 0.
So if i re set it up i should have brakes?
Backed what down to zero? If you mean your EPA is zero then, yes you will have no brakes.
Set your throttle and brake EPAs at 100% on your radio. Then go through the initial setup again on the GTB2. Once you verify you have brakes, you can adjust the brake side EPA to a lower value if it's too aggressive.
epa is 100% and expo is 0 as per instructions. i re set it up and i have brakes yay. not awsome but a massive amout more than before.
thanks
matthew
thanks
matthew
After a test run today the brakes seem enough to stop it pretty quick due to its ultra light weight.
