Orion R10 1s ver SP gt
Hi
Thinking of buying a Orion r10 for my top rebel , but have tried the Sp speedo and is woundering if its the same electronic , as the setup via the box looks VERY MUCH the same , any ideas?
The sp shuts down because of heat , runs 1s and 3,5 turn SP (by far the quickest motor on our track) and no problems with Nosram speedo
Can tell you that I have tried the SP , and it shuts down because of heat. With same gearing and motor I tried a Nosram and no problems.
What model SP, and what firmware and settings have you tried? The SP has a lot of adjustability, which can be either good or bad depending.
Have you tried posting your setup in the SP thread in the on road forum?
Have tried almost every setting in the speedo , it was a GT 2,1 , the low one for 1/12. Have even tried with a fan , and still it shuts down. Tried with the settings from SP home page for 1/12 modified , and still shuts down , speedo has been sent to SP and they just say it has been hot , YES thats the problem. Speedo stayed at SP as it was to expensive to have it shipped back. So I just want to be sure that the new R10 1s speedo is not made the same way as the SP
Not sure what you were running but 8 had theni sp gt 2.0 pro running my losi scte with a trinmity 550 3.5 fastest sct motor out with a 12 tooth pinion and the esc. Was straight our of box no heat issues
