Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-01-2012, 11:50 AM   #1
Default MAMBA MAX PRO ON/OFF SWITCH.. CUT IT ?
i just got a new mmp and ive heard that the switches suck. should i cut it from the get go or have they gotten better ?
thanks
twisted is offline   Reply With Quote
Old 08-01-2012, 12:11 PM   #2
AlienModified's Avatar
Yes, cut it off. CC's switches are garbage.
AlienModified is offline   Reply With Quote
Old 08-01-2012, 12:14 PM   #3
Might also be a good idea to go to a place like Radio Shack and get a good switch.
Old 08-01-2012, 12:44 PM   #4
is there a certain type of switch ? i ask because back in the day i cut one off a evx 2 and soldered on another switch and it blew the esc...dont ask me how as i do not know.
all i know is the wires melted together from the switch and the esc smoked.
Old 08-01-2012, 03:49 PM   #5
bluef250's Avatar
get a novak switch, i replaced mine with one and havnt had an issue yet
bluef250 is offline   Reply With Quote
Old 08-01-2012, 03:49 PM   #6
tc5 man's Avatar
Yea cut that switch off man on my Mamba Monster i tryed many things to stop it from coming off on my Truggy and it got tanged in my driveshaft so i just hardwired it and never had a issue ! Just make sure when your done running to unplug the lipo very important .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 08-01-2012, 06:23 PM   #7
OldGuydust's Avatar
Trader Rating: 18 (100%+)
Cut it.. I replaced one with radio shack stuff, was all good. I also hardwired one, all good..
OldGuydust is offline   Reply With Quote
Old 08-01-2012, 06:44 PM   #8
Super Moderator
Everything I'm aware of just needs the simplest switch, a so called SPST, single pole single throw. Closing the contacts between the two switch wires turns on the ESC. As some have mentioned one can hardwire them together to bypass the switch. (Edit: Might need another switch to completely replace a 3 wire deal with a setup button.)
Which does make your bad experience a little difficult to understand, about all you should be able to do messing with the switch is turn the ESC on. Possibly contacting ground with the wires, while connected to the battery? Or some stray solder? No attacks, just wondering, that is weird.
+ Absolutely. If I can add, even with a working switch it's important to unplug a lipo. Parasitic drain can take them out, its happened to more than a few guys.
Dave H is offline   Reply With Quote
Old 08-01-2012, 07:52 PM   #9
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
wait, why are you cutting it off?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-02-2012, 01:48 PM   #10
Because the switches that Castle uses are weak. I had one shut off mid-race one.
Also, hardwiring the wires can be a pain in the rear when you get done racing and need to corner marshal. I did that for a while I found it is better to have a new switch instead.
Old 08-02-2012, 01:51 PM   #11
I servo tape mine against the chassis with the switch going left to right. maybe that is why no issues.
Old 08-02-2012, 01:59 PM   #12
Could be.
Old 08-02-2012, 03:54 PM   #13
Super Moderator
Never mount the switch with off towards the front or down. The directions that typically take the biggest impacts. Seen about every brand shut off if mounted that way.
Old 08-02-2012, 05:36 PM   #14
Hard wire it, it is going to quit working eventually and you don't want that to happen during or just before a race.
cecce12 is offline   Reply With Quote
Old 04-11-2015, 08:56 AM   #15
My switch wires broke at the board, can I solder a tab across or should I solder new wires on and then bridge
Rylo31 is offline   Reply With Quote
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Mamba Max Pro ESC (2 for sale) and BEC skerry1 R/C Items: For Sale/Trade 9 05-06-2012 07:27 AM
Mamba Max Pro w/ castle Link and Team Epic 4.5 pickle311 R/C Items: For Sale/Trade 11 04-28-2011 08:34 AM
Tekin RS, Tekin 1700 KV, Mamba Max Pro, Servo & More jkirkwood R/C Items: For Sale/Trade 11 02-16-2011 05:53 PM
