Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-02-2013, 04:06 AM   #121
miles514's Avatar
How does the Trackstar 21.5 fare with the other 21.5 out there? Im thinking of getting this also for my F104...
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 04-02-2013, 04:23 AM   #122
Originally Posted by mtaddei View Post
Ciao to all,
on my 13.5 i need more rpm, i must replace the original rotor with one having a dia of 12.3 or 12.0 mm. Do you know which brand will fitt in???
Tnks
Max
I thought the reedy brushless motors are the same as turnigy trackstar motors, so i guess the rotors are interchangeable.
But i can't confirm that.
addicted2blue is offline   Reply With Quote
Old 04-02-2013, 05:29 AM   #123
Ciao addicted2blue,
tnks a lot for yr replay.
I was thinking that also lipotech rotor was good, but they use a different bearing size, so, if also the can are the same, the rotor doesn't fit .
The cost of reedy rotor is more then the cost of the hobbyking motor!!!, before to procede with the purchase i must be sure 100%!!!
Ciao
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 04-02-2013, 05:34 AM   #124
choisan's Avatar
what is the difference with this and its mach2 or 4?
choisan is offline   Reply With Quote
Old 04-02-2013, 11:08 AM   #125
nrtv20's Avatar
Their 21.5 is... FAST It is what our local fast guys run.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 04-02-2013, 06:19 PM   #126
ta04evah's Avatar
Ciao addicted2blue,
Ciao
Max
Yes, the Reedy rotor will fit into a Trackstar and vice versa. Note, if you switch rotors, use the shims that came with the motor because the Trackstar and Reedy have different sensor board arrangements.
For example if you bought the Reedy rotor don't use the shims that come with the Reedy rotor, instead use the ones that are in the Trackstar motor and take note of which shims are on each end of the Trackstar rotor when you pull it out..
And you are correct, the Reedy rotor is more expensive than the cost of the Trackstar motor. That's why I and a few other guys at our track are using them for club racing, they go just as good as the big $ brand motors and are 1/3rd the price.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 04-02-2013, 06:36 PM   #127
cyanyde's Avatar
These are not the Turnigy Mach Versions. They are the new Trackstar ones.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 04-03-2013, 06:39 AM   #128
choisan's Avatar
Let me clarify. what is the latest version or design of the track star, please kindly advise
Old 04-03-2013, 08:57 AM   #129
Cheers
Rob.
Ciao Rob,
you are right the motor is excellent, low temperature and lot of power at a very affordable price. But i need a top end speed, i'm using full motor timing but my local track is a very fast ones, used in the past for 1/8 onroad cars!!, and on the straight my top speed is not enough, so the only way is to change the rotor with a smaller one!!!!
Tnks a lot for your advice.
Ciao
Max
Touring: WRC STX
Old 04-03-2013, 04:04 PM   #130
cyanyde's Avatar
We're talking about this motor:
/Adrian.
Old 04-03-2013, 04:06 PM   #131
cyanyde's Avatar
Ciao Rob,
Ciao
Max
Gearing up don't work?
/Adrian.
Old 04-03-2013, 04:28 PM   #132
choisan's Avatar
thanks, i have this one. Since i saw a “mach” version, i want to know what are they? Are they the newer version? How is this trackstar compared with those “mack”?
Old 04-03-2013, 05:25 PM   #133
Suspended
Because i do not race sanctioned events and have no need to have "Approved" by anyone items, I have been using hobbyking motors for a while. I have them in X-Car, Trackstar both silver and red and no name brand as well. I have never had one let the smoke go and they are just as good as other motors i have owned mostly LRP and Hobbywing. In buying new motors it is now HK all the way for me. The same goes with ESC's as well. Other then the couple of HW Just Stocks i have everything else is HK.
RogerDaShrubber is offline   Reply With Quote
Old 04-03-2013, 07:06 PM   #134
ta04evah's Avatar
Ciao Rob,
Ciao
Max
As Cyanyde said, have you tried changing the gearing on your car? These motors have lots of torque and can withstand high temperatures, so increasing the roll out on your car could be an option to take first?
Cheers
Rob.
Old 04-03-2013, 09:10 PM   #135
miles514's Avatar
I have yet to try their Trackstar Motor and Trackstar esc. So far their nano tech battery and BMS servos are great, cant complain about their performance and price
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
