Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-23-2014, 10:59 AM   #466
Wade....'s Avatar
I really like these motors but they are not perfect. Had a 17.5 with a bad phase out of the box last week.
Dremeling the timing plate will get you more timing for onroad. These motors have little timing built in, but very torquey and friendly to novice. Also heard a Reedy timing board pops in and gives a static timing boost so you can avoid getting the dremel out.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 12-23-2014, 12:06 PM   #467
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Troy Carter View Post
3.9 isn't enough gear for boosted. Start around 6:1 and add boost to your liking. You may be able to go lower but I would start there for boosted and work my way down if I was running 21.5.
For F1 4.0 is right for 21.5 boosted starting point. At 6:1 the motor will top out almost immediately on the straight. With the torque there will be a lot of wheel spin in the twisty bits.
Without boost, on rubber tires we were running the same motors @ 2.75 to 3.25 FDR and they're coming off under 130 without fans. The only thing I can think of is that the light weight of the car decreases the amount of torque required from the motor to make it go.
I have another on order for my CRC WTF-1.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-23-2014, 12:09 PM   #468
I run the 21.5 in my USGT car (no boost) on a 90x40 carpet track. I gear between 3.4 and 3.6 FDR. Its never been over 130 with a fan. Good motor.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 12-23-2014, 04:07 PM   #469
I've been running this in my usgt and had the fan fall off but the motor only came off at 150F after 8 min. 3.5fdr. Usually with a fan it's been coming off at 120-130F.
Friulimotosport is offline   Reply With Quote
Old 12-23-2014, 04:15 PM   #470
miles514's Avatar
very good motor and very cheap too!
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 12-23-2014, 06:34 PM   #471
golgi's Avatar
Trader Rating: 14 (100%+)
I've been using the 21.5 in my F1 for almost two years now and it's been great.
golgi is offline   Reply With Quote
Old 12-23-2014, 07:14 PM   #472
How do you adjust the timing. I have undone the 3 screws and i cannot move it even a mm. Any hints guys and girls?
70URA is offline   Reply With Quote
Old 12-23-2014, 07:52 PM   #473
sometimes they are pretty tight. i had to use a set of pliers and a piece of cardstock to protect the finish to get it to turn.
dragonracing is offline   Reply With Quote
Old 12-23-2014, 08:03 PM   #474
Thanks so much for the reply, worked perfectly. I just didnt want to get too forceful with it without asking, incase i broke something.
Old 12-23-2014, 08:11 PM   #475
Madulla's Avatar
Timing at zero is 19-20 degrees. Max timing was at 30-31 degrees on my tester.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 12-23-2014, 08:41 PM   #476
DBM
No wonder people say it is fine to just crank the timing on these motors.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 12-23-2014, 08:57 PM   #477
I have a Trackstar 17.5 in my buggy and a 13.5 in my tourer, pleased with their performance but I find they both run hot. Finish a 6m buggy run on a warm day and the temp is around 75c with stock timing. If I switch it to my Speed Passion 17.5 and do the next race the temp is around 55-60c (stock timing as well). 2wd rear mount buggy so there is no way to mount a heatsink or a fan..
Flanker is offline   Reply With Quote
Old 12-24-2014, 02:11 AM   #478
ta04evah's Avatar
Hobbyking has now released another 540 size brushless car motor called the "Hobbyking X-Car"
http://hobbyking.com/hobbyking/store...r_1489Kv_.html
The kv ratings are lower than the Trackstar counterparts, and a little bit more expensive, wonder if they'll submit them for ROAR approval as well.
Cheers
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-24-2014, 07:31 AM   #479
Interesting. Will have to look into these.
Old 12-24-2014, 07:45 AM   #480
DBM
You might need to go a tooth smaller on the pinion with the trackstar motor.
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
