Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-20-2014, 05:36 PM   #451
SRC_DRIVER's Avatar
Trader Rating: 60 (100%+)
I'll say it again. I've had nothing but good luck using these motors. I've ran everything from the 21.5 I'm not M05 Pro all the way to a 7.5 I have bolted in my Open 2wd SCT with no issues at all. Always as fast and most of the time faster and for 1/4 of the cost!
www.Medlinracing.com
http://www.youtube.com/watch?v=VVIyGKSyAGg
SRC_DRIVER is offline   Reply With Quote
Old 12-20-2014, 05:38 PM   #452
SteveM's Avatar
Trader Rating: 133 (100%+)
Thumbs up
What he said! Great motors for the price.
SteveM is offline   Reply With Quote
Old 12-20-2014, 06:31 PM   #453
Originally Posted by killeraxemannic View Post
What kind of fan do you guys recommend? A clip on heatsync one or something else? I have the fan scoop kit for the TC4 that pulls air from under the car through some large holes in the chassis. Should I run that or something else? It worries me because it pulls air from under the car and that makes me think it will cause lift in the corner that its under
a clip on is fine. i run the WTF fan from the awesomatix guys. good fan. any of the fans are good. but get one that you can wire direct to your esc to get 7.4v. so when youplug the battery in the fan is on regardles if the car is on or not. you can race...finish put the car on bench and leave plugged in and the fan will cool down your motor.
dragonracing is offline   Reply With Quote
Old 12-21-2014, 05:15 AM   #454
CFRacing's Avatar
hey guys need some help here. will be running 21.5 f1 on foam tire carpet track boosted what would be a good starting point for gearing this motor? it is the red trackstar. any help woud be greatly apreciated.
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
CFRacing is online now   Reply With Quote
Old 12-21-2014, 06:29 PM   #455
Well I just got done running my 21.5 with a 4.17 FDR and my temps were at 130 after the race with no fan! I wasn't getting pulled in the straights last time and took .4 seconds off my average lap time. Going 3.8 FDR next race! Definitely pleased with the motors performance. Just as everyone else has said these aren't really any slower than anything else out there.
killeraxemannic is offline   Reply With Quote
Old 12-21-2014, 06:36 PM   #456
is your track fairly small? whats the straight length? i would gear fo the motor to top out just at the end of the straight. then it should be fairly quick in the infield.
Old 12-21-2014, 06:45 PM   #457
I really don't know what's considered large or small but I am definitely at full speed and have the motor topped out about 1/4 of the way in to the straight with the 4.17 gearing.
Old 12-21-2014, 07:09 PM   #458
gear it up some more. go to a 3.8. it should top out at about 3/4 to 7/8th of the straight. your speed will go up alot and lap times will improve also. its under geared. but...add a fan for sure. a cooler motor means less resistance and more power! Heat makes resistance thus limiting power flow in the motor. keep em cool as you can. good luck. i love these motors.
Old 12-21-2014, 08:40 PM   #459
CFRacing's Avatar
our carpet track is about 80x45 semy technical infield.boosted 21.5 foam tire.
thanks in advance
kyosho tki 4
Kyosho M3 evo
SpecR R1
Exotek F1R3
Old 12-21-2014, 08:52 PM   #460
thanks in advance
ok go to a 3.9. that should get you there.
Old 12-21-2014, 09:05 PM   #461
alcyon's Avatar
Originally Posted by Pro10noob View Post
Try moving them without pinion.
If you feel a strong magnetic field then it is normall that it seems that they "cog".
This also exlaines the "noisy" low speed running.
I got the silver can 10.5 Trackstars and they do the same at low speed.
When running at high speed it is gone.
Regards Roy
Glad to report that my 10.5 works great in my Buggy, speed is alright and its reliable so far.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 12-21-2014, 09:18 PM   #462
Trader Rating: 20 (100%+)
3.9 isn't enough gear for boosted. Start around 6:1 and add boost to your liking. You may be able to go lower but I would start there for boosted and work my way down if I was running 21.5.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 12-21-2014, 09:39 PM   #463
not sure about boost. we only run blinky. so what he is suggesting might get you there.
Old 12-21-2014, 11:59 PM   #464
Im currently running in my F1 a thunder power 21.5t with 79/19 gearing for a small indoor carpet track (lap record is in the 10sec range but we fade to mid 11s near the end) Finished 3rd in the championship but the motor is a year old and we run 100 lap and 50 lap races (100 lap races are 18-20mins long) so it has some time on it now and is loosing some power.
If i got the trackstar 21.5t what would you go timing wise and gearing for a starting point. We run blinky and foam tires.
70URA is offline   Reply With Quote
Old 12-22-2014, 11:50 AM   #465
run the timing to the max on positive side (this equates to about 35 degrees of timing) and run it at about a 3.8 to 4.0 for your smaller track. if your tp motor was at 4.15 then a trackstar you can put a little bit more gear to it since it does not have as much timing built into them. they have alot of torque so you can gear them up a bit more. try a 3.8 to 3.9 to start and them monitor temps. try to stay under 130. thats my goal with these. they run the best under 130 degrees.
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
