Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 10-28-2014, 06:21 PM   #421
Originally Posted by Flanker View Post
Noob question, does anyone know how to increase the timing on the sensored 17.5 Trackstar motor? I've removed the end screws but cannot get it to budge. Don't want to pull it all apart, am I doing something wrong? Really want to increase the timing by about 10 degrees.
dont remove them all the way. you might have to use pliers and use some kraft paper or construction paper or something to protect the aluminum from getting marred up. i had to a few times. some of them are very tight. the timing marks that are on the car are as far as the timing will go. its not much but i have found these motors to have alot of torque so i can gear them a little more than a regular motor. good luck.
dragonracing is offline   Reply With Quote
Old 10-30-2014, 06:27 AM   #422
Thanks Took a bit of effort but I managed to increase it by 20 degrees
Its getting up to 65c during longer runs, is that a bit hot?
Flanker is offline   Reply With Quote
Old 10-30-2014, 07:00 AM   #423
Trader Rating: 23 (100%+)
65c is comfortable operating temp. If you're coming off around 75-80 then it might be getting a bit warm in there
Zhangesh is offline   Reply With Quote
Old 11-04-2014, 10:35 AM   #424
RotorTruck's Avatar
I ran a brand new 21.5 red Trackstar in Outlaw VTA last weekend and just wanted to say it's quick. Pulled a Schurr Speed motor on the straight. hottest it got was 144*F measured by telemetry sensor zip tied to the top of the motor can. 2 other sessions were at 133*F. Motor timing is maxed out, about one half tick from full timing on the label. Does this sound about right? No fan or heat sink.
I also added two drops of 3-in-1 oil to the front bearing (pinion end) out of the box, and it the rotor noticeably moved quicker and smoother.
Best $30 purchase I've made in a long while.
RotorTruck is offline   Reply With Quote
Old 11-04-2014, 10:51 AM   #425
put a wtf fan on it and it runs even cooler. i always run a fan. @7.4v wired direct to esc battery wires so when its plugged in the fan runs. my 21.5's ran at around 130F outside in hot weather 80-90+ air temps. these are good motors. now iim running a 17.5 and its only getting to 115 indoors on carpet. max timing.
Old 11-04-2014, 01:07 PM   #426
Fredp1's Avatar
These motors are a really good buy.
What fdr ratio are you running , pinion/spur sizes? Thanks
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 11-04-2014, 03:30 PM   #427
last summer i ran 21.5 vta. a good starting point is a 3.6 fdr. 88/48 is a good gear set to start with. if you need a little more go up to a 88/49 for a bit more speed. these motors have alot of torque.
Old 11-04-2014, 03:31 PM   #428
DBM
Got to run my 21.5 and 17.5 motors on a bigger track this weekend. They definitely hold their own. No one pulled on my 21.5 car on the straight. I think it was the fastest car in its class down the straight. It looked to have less jam in the infield, but my punch setting is only at 10%.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 11-05-2014, 11:59 PM   #429
RotorTruck's Avatar
3.43 FDR in a TC4 on a track about the size of a tennis court.... 40 pinion and 55 spur.
Old 11-06-2014, 10:04 AM   #430
Fredp1's Avatar
I've been running it at about a 3.0 fdr and it was temping at 45c, very cool.
I'll try smaller pinion to allow the motor to rev more.
Old 11-20-2014, 10:41 AM   #431
71schaeffer's Avatar
Trader Rating: 7 (89%+)
What are good "blinky" esc's to run with the trackstar? I was wanting to run 17.5 short course class, the only motor i see is the red one. Is that the correct motor now thats roar legal? I would run it in a 2wd slash. So coming from a brushed motor what gearing would you recommend for a tight indoor clay track? Sorry for so many questions. Im a noob lol
Hobbytown USA Gladstone,MO / StickyKicks RC
71schaeffer is offline   Reply With Quote
Old 11-23-2014, 03:30 AM   #432
alcyon's Avatar
I just bought 2 red 10.5 trackstars and installed into my 4wd buggies. Ratio is at 8.5. I find that when i hand push them they kind of cog. My team powers is very smooth. Also the motor seems abit noisy at low speed. Is this all normal.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 11-23-2014, 03:59 AM   #433
Pro10noob's Avatar
Try moving them without pinion.
If you feel a strong magnetic field then it is normall that it seems that they "cog".
This also exlaines the "noisy" low speed running.
I got the silver can 10.5 Trackstars and they do the same at low speed.
When running at high speed it is gone.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-23-2014, 03:32 PM   #434
Has anyone ever ran one of these 17.5 or 21.5 with an LRP Flow ESC? How do they preform?
killeraxemannic is offline   Reply With Quote
Old 11-23-2014, 03:53 PM   #435
ran both the 21.5 and the 17.5 with a flow. works fine. both motors ran cool.\
timing on both motors maxed out and both ran cool with lots of power and torque.
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
