Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-01-2014, 11:06 AM   #406
Trader Rating: 25 (96%+)
Originally Posted by Rodney Racer View Post
I would attribute the performance difference more on the size of the rotor than the stators.
I agree that the TS rotor being 14% larger would certainly be the main factor, but I've heard really good things about the Vulcan stators, so I wonder if it would be a winning combination to mix both products together to get the best of both worlds while still staying 100% Spec Legal
It sure would be nice to find which brand offers the best rotor, and then mix it with another brand that offers the best stator!
billdelong is offline   Reply With Quote
Old 08-01-2014, 11:20 AM   #407
big_ads's Avatar
Trader Rating: 77 (100%+)
Send a message via MSN to big_ads
Need to be careful with this idea depending on how the tracks you race at view and follow rules. In the ROAR rules they do not allow for mixing and matching of parts. Technically you are not even supposed to use different endbells like a D3 endbell on a D3.5 ect.
If your tracks do not pay that close of attention, best of luck and let us know what you find out!!
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Team Genesis R/C Products - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 08-01-2014, 11:42 AM   #408
The tracks in my area don't follow ROAR, they do ask drivers to follow spec limits... so we are limited to 21.5T spec... regardless if ROAR decides to ban a motor, etc. I seriously doubt anyone would have a problem swapping parts between two motors which contain 100% spec legal parts.
For the most part, we can tell that all our cars are in spec anyway, the performance is fairly consistent, however I have seen a car once that made me wonder if it had a 17.5T stator in it
Old 08-13-2014, 07:43 PM   #409
will you please pull the rotors from TS and Reedy to confirm if they are identical?
Bill if KS = Kill Shot, I can answer that. the Kill Shot comes in a variety of rotor sizes and strengths 12.3mm to 12.5 mm (there are 13mm rotors too but those aren't ROAR approved for Spec racing) and RPM, broad power band, Torque. As I read the ROAR guideline only ROAR approved tuning rotors from the same OEM may be used in a motor. All of the KS rotors (except the 13mm) are ROAR approved for spec racing and are interchangeable with the D3. D3.5, Revtech, kill Shot and D4 motors. My RPM Kill Shot came with the 12.3mm broad band rotor. The Maxilla version comes with the 12.5mm torque rotor. Hope this helps t least for the Kill Shot motor
John Wallace2 is offline   Reply With Quote
Old 08-18-2014, 11:27 PM   #410
Just wondering. I have a brand new 21.5. How far round can the timing go out of the box? I have turned it as far as I feel possible and the pointer is between the last line and the 2nd to last line. If someone can confirm this is normal, it would be much appreciated.
thanks
Mike
ixlr8nz is offline   Reply With Quote
Old 08-18-2014, 11:45 PM   #411
thanks
Mike
Thats as far as it goes without internal grinding.
dragonracing is offline   Reply With Quote
Old 08-19-2014, 01:36 AM   #412
How hot do these motors run?
I'm running a 21.5 in blinky mode with an old xerun 2.0. Its getting just above 70 degrees celsius with no timing running 3.3FDR and no timing. That seems hot to me, but I am new to RC.
I'm also finding that it is a bit slow compared to the other cars in the field. Any advice?
Ryan
Tamiya M05
Spec-R S1
filippimini is offline   Reply With Quote
Old 08-19-2014, 10:32 AM   #413
i run a 3.6 fdr. temps get to 130 Farenheight 54C celsius.
Old 08-19-2014, 10:34 AM   #414
your temp is fine. if you get close to the 90C temps thats way too hot. anything under 65.5 is very safe. but not much over that.
Old 08-19-2014, 10:35 AM   #415
max your timing and gear down to a 3.5 to 3.7 in that range and it will come alive.
Old 10-24-2014, 05:50 AM   #416
Trader Rating: 23 (100%+)
Anybody recommend a starting FDR & timing for blinky 17.5 TC? medium sized track, thanks
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-24-2014, 10:21 AM   #417
DBM
For small indoor track (55' straight, very tight infield), I'm running between 4.3 and 4.5 fdr. For a bigger indoor track (85' straight), I was running around 3.97 - 4.05 fdr.
Edit: this is for my 17.5 car in blinky. It gets to around 149F after 5 minutes at 4.3, but Onyx gets to 135F at 4.5fdr.
I also run a 21.5 in vta between 3.91 and 4.10fdr on the little track. Timing is almost maxed. It also gets to around 150F.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 10-25-2014, 03:54 PM   #418
hydrakermit's Avatar
Hi all,
I have the Turnigy Trackstar 13.5T motor and the Turnigy TrackStar GenII One Cell 120A ESC, which will be going into my GT12 GT once it arrives.
Links for motor and esc here;
Motor;
https://www.hobbyking.com/hobbyking/...dProduct=39887
ESC;
https://www.hobbyking.com/hobbyking/...dProduct=57973
Could anyone give me a FDR for this motor and ESC please? Also has anyone fount a "sweet" spot or a good point for the motor timing for the 13.5T motor please?
Many thanks in advance.
hydrakermit is offline   Reply With Quote
Old 10-26-2014, 05:07 AM   #419
Not sure if this was already explained, but info on the OP is rather limited.
I recently pulled the rotor out of my Trackstar motor and found it to be roughly 14% larger than the rotor that came with my Novak Vulcan motor:
Turnigy (Black): 12.5 x 28.4
Novak (Silver):12.3 x 25.3
I also found that the stator could be swapped out and was able to fit the Novak stator in my TrackStar just fine, which can provide a nice tuning option:
Has anyone been able to confirm if the Reedy Sonic rotors will fit the TrackStar motors?
The swapping is not legal and the Trackstar you are showing (Gray can) is not one of the ROAR approved versions. They are red. The rotor that was approved by ROAR in the Trackstar was 12.5mm (ROAR Max for spec).
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 10-28-2014, 05:56 PM   #420
Noob question, does anyone know how to increase the timing on the sensored 17.5 Trackstar motor? I've removed the end screws but cannot get it to budge. Don't want to pull it all apart, am I doing something wrong? Really want to increase the timing by about 10 degrees.
Flanker is offline   Reply With Quote
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
