Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-21-2014, 11:19 PM   #376
poeee's Avatar
Are they all ROAR approved now, or is it just the 21.5, 17.5 and 13.5?
Scott Pocock | Geelong Radio Control Car Club www.grccc.org.au
poeee is offline   Reply With Quote
Old 04-22-2014, 05:28 AM   #377
Trader Rating: 25 (96%+)
I see the 4 Pole SCT motor listed here too:
http://www.roarracing.com/approvals/...lessmotors.php
billdelong is offline   Reply With Quote
Old 05-04-2014, 02:34 PM   #378
V12
V12's Avatar
Saw a Trackstar motor (red) at the pits and it looks and feels really good. Interested to try out at a Pro10 car.
If set to zero at the endbell, how much timing is this in reality?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 05-05-2014, 05:24 AM   #379
Fredp1's Avatar
Originally Posted by nexxus View Post
My first run with the 21.5 I had people checking to make sure I wasn't cheating, the top end speed was insane, it pulled like a tractor out of corners and was consistent the whole run.
Hi Nexxus,
What kind of car were you running, 1/10th touring, blinky?
Can you share the fdr and end bell timing?
Fred
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 05-05-2014, 05:46 AM   #380
I don't know but i have 6.5 and 5.5T with pancar and works fine with Xerun and Radon but with Reventon need a lot of internal timing and don't work fine with this ESC.
regards
TyoBBS is offline   Reply With Quote
Old 05-05-2014, 07:18 AM   #381
DBM
I've been running a trackstar 17.5 in tc stock for about six weeks now. It doesn't seem to give up anything to other big name motors, neither gaining or losing ground down the straight. I let a fellow club member try out my spare motor during a practice night. He was about 0.1 off the pace of his motor, but it wasn't due to a lack of power, but it was due to the power bands being very different (the trackstar is very torquey out of tight corners). If he had a couple of more sessions to adapt to the character of the trackstar (or change his gearing, or turn down the punch), I'm sure he would be right on pace. For $30, they seem to be a damn fine motor.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 07-12-2014, 10:48 AM   #382
Default Mechanical timing
So I've seen two posts on this and no reply. To adjust the timing your supposed to loosen the three screws and twist +/- right? I have a 17.5 and it does not move at all even if I remove the screwed. I had to leave my wrench in a screw and tap the wrench with pliers to get it to move. I have two 8.5 but I haven't tried the timing on those. So the question is it normal/safe to do what I did? The motor did not get hot after about a 15min run but it still was slow. The esc could be blamed for the slowness though.
Nisstyre is offline   Reply With Quote
Old 07-12-2014, 12:46 PM   #383
Trader Rating: 26 (100%+)
Dude I'm having the same problem!!!
Funny I was about to post the same damn ?.
I cant increase or decrease the timing?
I'm running mine in a tc6.1,what fdr are u Guys running with this motor?
winstoncup is offline   Reply With Quote
Old 07-12-2014, 01:56 PM   #384
cyanyde's Avatar
It gets pretty tight and tapping it lightly is fine. A better solution is to disassemble the whole endbell/sensor component and slightly lubricate the rubbing parts.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 07-12-2014, 06:19 PM   #385
Thanks this worked to a degree.. I have to loosen all six screws to adjust timing.
For some reason the screws holding the motor together locks the timIng adjust down.. Not a big issue tho
Old 07-12-2014, 07:55 PM   #386
i actually had to use a pair of smooth (no teeth) pliers to make the timing move. looking at the endbell rotate clockwise. i run mine full timing.
what size motor? 21.5? (3.7 to 3.9) thats my range i run mine at for med to large tracks.
dragonracing is offline   Reply With Quote
Old 07-13-2014, 07:48 AM   #387
I have the 17.5. Currently i have it geared 72/41
For. 3.5 fdr and zero timing.
Thinking about 72/39 with some timing added
Old 07-13-2014, 10:53 AM   #388
Thata pretty tall for a 17.5. I would go to more of a 4.0fdr for a 17.5. I gear my 25.5 at a 3.5. So thats very tall for the 17.5. 4.0 to 4.3 and that motor should be happy. Temp wise.
Old 07-13-2014, 05:32 PM   #389
Default Gearing
I did raise the fdr to 3.89. I'll start there with 0 timing.
I will try and test it tomorrow at my local track.
Old 07-17-2014, 07:17 PM   #390
didnt ask since ive been working alot. what size track? small? med or large?
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
