Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-20-2014, 03:27 PM   #361
Potoczak's Avatar
Trader Rating: 109 (100%+)
Is anyone running a 10.5?? Could someone recommend a starting fdr?? Small to medium outdoor asphalt track. 80ft straight.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-20-2014, 03:40 PM   #362
Pro10noob's Avatar
I am running them but not in TC but pro10
Don't think you could use that tho.
If it is none boosted try 5.5 for starters and temp after 2 minutes
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-20-2014, 11:22 PM   #363
Regards Roy
Good news! Blue car with default settings 78/15 (48P)
ESC Radon + 5.5T trackstar:
https://www.youtube.com/watch?v=qOAhn_I_wxM
+ YouTube Video
Your settings? THANK YOU in advance,
TyoBBS is offline   Reply With Quote
Old 04-20-2014, 11:36 PM   #364
Pro10noob's Avatar
Will check setting today and send them to you.
We in Holland run the 10.5 in the Pro10 class with boost and or turbo.
I am running it with a HW 2.1 esc and running it with 78/19->22 pinion depending on tire diameter.
Good speed and it ripps out of the corners very good
Some movies from the stock races here in Holland
Regards Roy
https://www.youtube.com/watch?v=6lUZ5UNKLRA
https://www.youtube.com/watch?v=OD_FCe-FlL0
+ YouTube Video
l===/o\===l
Old 04-21-2014, 12:38 AM   #365
Pro10noob's Avatar
This is what i am running with the trackstar 10.5 silvercan motor in the pro10
Dragbrake: 5%
Voltage protection: 3V/cell
DRRS punch: lvl 6
Brake force: 60%
Reverse force: 100%
Initial brake: Drag brake
Neutral range: 6%
Boost timing: 64
Turbo slope: 3
Overheat protection: Enable
Turbo timing: 1
Start RPM: 1000
Turbo delay: Off
Timing acc: 450
Hope this will help you some.
Motor is after 7 minutes 55 to 65 degrees celcius.
Regards Roy
l===/o\===l
Old 04-21-2014, 05:45 AM   #366
Thanks Roy, very interesting settings (like: Start RPM: 1000). I hope one day will go to Mach or Benelux race.
I like trackstar motor and works great with ESC TeampPowers Radon anyone have a setting for 5.5T (PRO10)?
regards
Old 04-21-2014, 10:50 AM   #367
For what it's worth, HK now lists these motors as "ROAR Approved" on their site.
rallyredevo is offline   Reply With Quote
Old 04-21-2014, 11:55 AM   #368
Pro10noob's Avatar
Start with no timing or boost and drive it till you find that you can go faster.
If so, try first a bigger rollout before you go fidling with the esc settings as a mod motor is much smoother then a stock motor with timing and boost.
If everything is going like you want it to, apply some timing but start low.
Temp motor after 3 minutes and work your way from there.
Regards Roy
regards
l===/o\===l
Old 04-21-2014, 03:11 PM   #369
(0000000000)'s Avatar
I currently used reedy sonic machine 1 and Novak ballistics.
17.5 touring and 21.5 VTA.
How does the track star compare to both of these motors on carpet?
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 04-21-2014, 03:44 PM   #370
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Better
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-21-2014, 04:17 PM   #371
pettyeagles's Avatar
Trader Rating: 79 (99%+)
Motors are very even if not slightly faster.
A bad day racing beats a good day at work. My RC fleet:
SC5M, B5M, FT B4.2, SC10.2, FT SC10(x2), FT TC5, FT TC4, 12R5,
AE Rival MT, RC10 Classic, CW Pro Comp Outlaw, F104, F104 pro v2, RJ Speed Legend
Traxxas Slash(x2), 4x4 Slash VXL, Vendetta SC/ST
Axial SCX10, Axial Yeti, G-Made/AX10, Losi Micro Crawler, Sakura D3 CS(x2)
pettyeagles is online now   Reply With Quote
Old 04-21-2014, 04:33 PM   #372
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
I thought my 17.5 trackstar was the same if not better than the reedy sonic 1 new endbell.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 04-21-2014, 05:25 PM   #373
nexxus's Avatar
Trader Rating: 297 (100%+)
My first run with the 21.5 I had people checking to make sure I wasn't cheating, the top end speed was insane, it pulled like a tractor out of corners and was consistent the whole run.
Awesomatix A800X / A800
nexxus is offline   Reply With Quote
Old 04-21-2014, 08:02 PM   #374
I agree it does pull very strong from a stand still it was very nice
Justin & Matt Lyons
a800s sanwa m12s
Old 04-21-2014, 10:36 PM   #375
Trader Rating: 152 (100%+)
Is the silver can trackstar same as the red ones?
S I O is offline   Reply With Quote
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
