Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-26-2013, 01:53 AM   #196
How do these motors handle boost/turbo?
thefan is offline   Reply With Quote
Old 09-26-2013, 08:23 AM   #197
Read through the whole thread
Very informative, so thanks for that
I have just one question. I can only find a "red can" 17.5T, is it the same as the "silver can" 17.5T mentioned in the beginning of the thread? Did they just change the color to red?
Reason I ask is in the beginning of the thread posters talk about the "red can" being lighter and having more torque
This is the link to the 17.5T turnigy trackstar motor at HK, is it the same as the original motor talked about in this thread?
http://www.hobbyking.com/hobbyking/s...or_2270KV.html
If its not, can someone supply me with the correct link to the motor talked about in the original post?
It's better to burn out than to fade away
WarWest is offline   Reply With Quote
Old 09-26-2013, 08:38 AM   #198
Trader Rating: 27 (100%+)
I'm pretty sure they're the same motor, just a color change.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 09-26-2013, 08:42 AM   #199
OK thanks!
Old 09-26-2013, 02:08 PM   #200
I took both a silver and a red can motor apart, and the only difference I could see is in the sensor end of the motor. It looks like the sensor board and timing ring are slightly different in the new red can. At first glance, it looks like the red can timing won't advance as far as the silver, but when you crank them both as far as they go the sensors end up in the same place. I think it's just that the markings on the outside of the red can don't line up correctly with what's going on inside.
Kevin Marcy is offline   Reply With Quote
Old 09-26-2013, 02:12 PM   #201
I could only ever get my silver can to go to two ticks from full motor timing. Some local guys running the Turnigy 21.5 motors have the same situation. It won't go all the way to the end.
Old 12-22-2013, 07:28 PM   #202
4WDriver's Avatar
Default replacement bearings
Anyone know the size of the larger front bearing?, or know exactly which Reedy replacements work for replacing the larger front bearing?
(this is a silver 6.5T from earlier this year)
4WDriver is offline   Reply With Quote
Old 12-28-2013, 03:37 PM   #203
4WDriver's Avatar
small one in the endbell is 3 x 7 x 3mm
large one on the front is 3/16" x 1/2" x 0.1960"
Old 01-25-2014, 11:46 PM   #204
ta04evah's Avatar
Roar Approval.
http://roarracing.org/4rmb/showthrea...tar-9192000035
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-26-2014, 05:52 PM   #205
Trader Rating: 49 (100%+)
does that go for only the 13.5 of the 17.5 as well?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 01-26-2014, 06:31 PM   #206
Wow, this is awesome. The Trackstar motors are some of the fastest motors I've run.
Old 01-26-2014, 07:07 PM   #207
MasterTech's Avatar
I had seen they had the same listing for the 13.5, 17.5 and 21.5 motors. They all said waiting on the availability deal.
MasterTech is offline   Reply With Quote
Old 01-27-2014, 06:02 PM   #208
Anyone know if these have passed for sure or not?
Jspires688 is offline   Reply With Quote
Old 02-08-2014, 08:03 PM   #209
Originally Posted by ta04evah View Post
Whoa man that's awesome
Hope they get approved
Old 02-10-2014, 12:31 AM   #210
I only use Trackstar motors and ESC's. Best electronics for the price hands down.
Measuredpath is offline   Reply With Quote
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
