Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-06-2013, 06:06 PM   #181
pettyeagles's Avatar
Trader Rating: 79 (99%+)
Originally Posted by pettyeagles View Post
Any body know what size bearing goes in these motors? I have a 9.5 red can and the bearing on the sensor board end exploded after about 4 packs in one of my drift cars. I run the 17.5 in sct and the 21.5 in F1 without any issues.
So the bad bearing took out the sensor board. Anyone know if the Reedy Sonic board will fit, or if a replacement board is available?
A bad day racing beats a good day at work. My RC fleet:
SC5M, B5M, FT B4.2, SC10.2, FT SC10(x2), FT TC5, FT TC4, 12R5,
AE Rival MT, RC10 Classic, CW Pro Comp Outlaw, F104, F104 pro v2, RJ Speed Legend
Traxxas Slash(x2), 4x4 Slash VXL, Vendetta SC/ST
Axial SCX10, Axial Yeti, G-Made/AX10, Losi Micro Crawler, Sakura D3 CS(x2)
pettyeagles is offline   Reply With Quote
Old 08-06-2013, 07:15 PM   #182
ta04evah's Avatar
It will fit, but only if you also use the end bell side of the outer "can" off a Reedy motor, and then you'll end up with a motor with 2 different brandings on it, and more than likely more expensive than to buy another Trackstar motor.
Also no replacement boards available. Bin the sensor part and keep the rest of the motor for spares (rotor, stator, can, bearing, shims) for your other Trackstar motors. Similar thing happened to one of mine as well.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-09-2013, 08:05 AM   #183
Born2Run's Avatar
I had to replace the bearing on the sensor board but looks impossible to take it out without damaging the sensor board.And since HK doesn't sell spares for these motors,i have one with broken rotor and damaged sensor and a second one with damaged bearing on sensor board.Practically both useless.
Whatever
Born2Run is offline   Reply With Quote
Old 09-09-2013, 08:27 AM   #184
cyanyde's Avatar
Bearing on sensor board?... Doesn't sound right. Any photos?
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 09-09-2013, 10:22 AM   #185
Born2Run's Avatar
Photos are a little blur but you can get the picture what i'm talking about
Whatever
Old 09-09-2013, 10:41 AM   #186
Born2Run's Avatar
I always use a remove bearing tool to take out the motor bearings .With these motors you cannot use this tool so i tried another method ( a small hammer and a 2mm Hex tip)and i managed to take out the bearing without damage the sensor board.Now let see if i can fit a new one.
Whatever
Old 09-10-2013, 01:55 AM   #187
Born2Run's Avatar
Very difficult to fit the bearing.Before insert it was turning free but now i can feel the grind.I don't know.Too much pressure from the Alu sensor body maybe? IMO this bearing is too small for a motor. Just 3X7X3.The smallest i ever seen on a brushless motor.
Whatever
Old 09-10-2013, 02:06 AM   #188
Suspended
After 6 months of beating the crap out of my 10.5T silver can trackstar in a blinky 10.5T on foam class, it also began to sound like a steam train, pulled it apart and there was a good teaspoon full of foam dust and track pickup in there, there are gouges in the rotor and i am certain one of the bearings has gone or is going.
But considering that it is still as fast as the day it was new, it has never been maintained, and it only cost $30 I am not complaining one bit. Best value for money motor there is on the market. Still runs cool also, with full timing, they take the punishment.
I have just replaced it with a Speedpassion MMM V3.0 that i use for ROAR approved needed races, which runs hot and is no faster than the Turdigy. Next order from hobbyking will have 2 new red Trackstars on it. For club racing, they cannot be beat.
RogerDaShrubber is offline   Reply With Quote
Old 09-10-2013, 02:13 AM   #189
Am trying to find a fast cheap 4.5t motor to run on 3s, but on their website it shows as only 2s capable, whereas the exact same motor but in 8turn is 3s capable.
Straange......any ideas?
smallnails is offline   Reply With Quote
Old 09-10-2013, 03:21 AM   #190
Born2Run's Avatar
4.5T on 3S is too risky.Not only for the motor but for speedo and batteries.Only the Castle creations 7700 could survive on 3s and this is not 100% sure.The risk is all yours.Good luck.
Whatever
Old 09-10-2013, 05:31 AM   #191
ta04evah's Avatar
+1
Plus that the rotor, bearings & stators will fit into a Reedy and vice versa.
A few of these motors are also starting to be seen in peoples cars during our club racing nights.
Cheers
Rob.
Old 09-10-2013, 06:45 AM   #192
cyanyde's Avatar
Did u try to desolder the board off first? Its no easy task but doable i think..
/Adrian.
Old 09-10-2013, 07:11 AM   #193
Born2Run's Avatar
NO.The only way is what i done and the next time it will be easier.Must be very gentle when trying to replace the bearing and it will be fine.
Whatever
Old 09-10-2013, 10:11 AM   #194
Hi also had a broken bearing in the sensor board.
I also had to tap the bearing with al little hammer to get i out, there was no other way that i could get it out. I didn't damaged the sensors but i wouldn't be surprised if i would be broken.
Then ordered 10 new bearings for 5 dollar on ebay.
I replaced the first one but damaged it because the hole in the sensor board was to small.
Then i made some kind of tool to make the hole a little bit bigger. I rolled a piece of sandpaper around a screw en put it in a drilling device.
Only use the drilling machine a few seconds or the hole wil be tho big and you can throw the sensor board away.
The motor is running perfectly now.
sitting duck is offline   Reply With Quote
Old 09-14-2013, 04:18 PM   #195
trick25's Avatar
Trader Rating: 25 (100%+)
does anyone know how many degrees each mark is on the endbell?
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Turnigy Trackstar 150A 1/8 scale brushless esc? Rich68 Electric Off-Road 143 05-26-2014 12:19 AM
Anyone use the Turnigy TrackStar 150amp ESC???? 440swinger-kid Radio and Electronics 11 05-26-2011 04:18 PM
