Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 11-19-2012, 11:24 PM   #121
nerdling's Avatar
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-28-2012, 07:50 PM   #122
zerocool77's Avatar
Send a message via Yahoo to zerocool77
Originally Posted by Ultraspeed84 View Post
are the LRP flows 160A?
I guess its 20A per phase X 7.4Volt... Its should be 140A...
~ Team Putra Serpent, Kch ~
zerocool77 is offline   Reply With Quote
Old 11-28-2012, 07:58 PM   #123
Trader Rating: 25 (100%+)
Has anyone posted their mod 1/12th settings for the flow?
www.teamkellner.com
fred kellner is offline   Reply With Quote
Old 11-28-2012, 08:02 PM   #124
seth556's Avatar
Trader Rating: 37 (100%+)
Incase you're looking for one, I found this. http://www.ebay.com/itm/LRP-Flow-ESC...item2ec3b21d29
seth556 is offline   Reply With Quote
Old 11-28-2012, 08:47 PM   #125
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Hebert did
Ask Keven Hebert, TeamAssociated / Reedy / ApexRC
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-29-2012, 04:28 AM   #126
IgorR's Avatar
LRP have posted on their web site the setup that Ronald Volker used during the last Worlds.
1/12 – LRP Flow Speed Control (#80970): v4.0 Software, 1-2-4-2-7-1-0
1/12 – LRP X20 Motor (#50704): 12.0 WorksTeam Rotor, 27.5° Timing, 34mm Rollout
Yokomo BD7 16, YR-X12
IgorR is offline   Reply With Quote
Old 11-30-2012, 12:50 AM   #127
Does anyone out there have been running the Flow with Thunder Power motor? I have been running Lrp Sxx V2 before but seems like the speedo not running very well with Thunder Power motor. The previous speedo just works well with LRP motor i guess. Pls advise if anyone have any experience with the Flow running Thunder Power motor.
mizah is offline   Reply With Quote
Old 12-02-2012, 12:04 AM   #128
jimkoimanis's Avatar
Me to my nosram hd is having ptoblems to with thunder power motors in blinky mode
I just cut the temp sensor wire and it seems to have fixed the problem
Its the second wire on the left hand side when looking at the bell end of the motor
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
Old 12-03-2012, 12:44 AM   #129
S_fender's Avatar
Hi,
Be carefull with world setup. I'ts not the same software.
Try 1-2-2-1-3-1-0.
Sébastien
S_fender is offline   Reply With Quote
Old 12-03-2012, 02:28 AM   #130
Any suggestions on ESC Setup and FDR for small to medium sized carpet tracks?
Motor is a X20 5.0T
Regards David
niemand is offline   Reply With Quote
Old 12-03-2012, 09:49 AM   #131
peter.'s Avatar
can anyone tell me or reedy SONIC Competition works good with a flow esc
peter. is offline   Reply With Quote
Old 12-03-2012, 11:18 AM   #132
B00t13g's Avatar
My reedy is beyond smooth with my flow.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-03-2012, 11:39 AM   #133
syndr0me's Avatar
Trader Rating: 32 (100%+)
It's shocking how much difference changing the throttle profile makes on this ESC. I couldn't believe how much the rip increased.
I wanted an ESC that I could set and forget, and this is it. I think I've got post-traumatic infinitely adjustable ESC syndrome.
syndr0me is offline   Reply With Quote
Old 12-05-2012, 01:35 PM   #134
NItrox416's Avatar
Hi all,
someone tried the new Flow competition in blinky mode?
In general which are the main difference with the SXX SS ?
Thank you for the help.
NItrox416 is offline   Reply With Quote
Old 12-05-2012, 02:13 PM   #135
Originally Posted by NItrox416 View Post
Hi all,
Hi I have the Nosram comet HD (=flow works team) version , Using it on 10.5t Pro stock blinky class. and compared to my old Stock Spec V2 this has a bit better throttle feel, but really nothing big, just a bit. This is also a bit larger.
I belive that the comp version is just the same, just fewer fetts.
Maybe some1 who has the comp will confirm that
-Pate
fastvee is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
