Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 01-24-2015, 07:55 AM   #1246
Could someone post there setup for V5.4 17.5 boosted.
I have been using the V5.0 untill now, but want to try the new software.
I am running indoor carpet Awesomatix, and need some advice where to go.
As now, my FDR are 7.13, but this can off course be changed.
Looking for some different setups, so please post yours, and this might give me an idear what way to go.
Thanks in advance
Shock Tower is offline   Reply With Quote
Old 01-26-2015, 07:17 AM   #1247
Thanks in advance
No one ?
Old 01-27-2015, 08:22 AM   #1248
Question about using the LRP Flow with 1s LiPo without booster or seperate battery.
Some people say it works,some say it doesnīt and some say it depends on the receiver.
Has anybody tried it with a Futaba (R304SB) receiver?
I bought a Nosram Comet HD (similar to the LRP), havenīt received it yet, and I hope I didnīt buy it for nothing...
Thankīs in advance!
TOP Rebel 12 - Nosram Comet HD - GM Racing 10.5 - nVision - Futaba
Associated B44.3 - Nosram Comet HD - Reedy 7.0 - nVision - Savöx - Futaba
M.Boos is offline   Reply With Quote
Old 01-27-2015, 12:59 PM   #1249
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thankīs in advance!
Try it and see
I've seen it work more often than not
Been running the SXX CompVII for a few years with no boosters, even with the updated boards
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-31-2015, 04:38 AM   #1250
Looking for some guidens regarding the newest software V5.4. Have been running V5.0 up till now boosted, 17.5, but want to try the new software. Could someone post there setup, so I have a starting point, to find my own personal setup.
Hope someone will post theres, thanks in advance.
Old 02-02-2015, 06:14 PM   #1251
Nat Maniac's Avatar
Originally Posted by Nat Maniac View Post
Just thought id let everyone know that i put a new novak gtb3 esc in the buggy and still the same issue...tried my other almost new motor...still the same issue.
Im going to call the retailer and ask them to send it back to me. I still cant figure out what the problem is. Changed motors, sensor cables...bloody mistery
going to take it to the track on Friday and get a few other opinions
perhaps user issue!?!?
I thought that I should post an update to this for anyone experiencing the same issue with their LRP Flow Works Team in future.
Other drivers who tested the car experienced no issues with the braking but other drivers did, specifically when the car was making high speed turns.
This turned our attention to the Savox servo. I replaced this but still appeared to have the same issue. Since then I purchased the bridge and updated the firmware to v3.8 off-road.
I'm happy to say that I no longer experience the lack of braking.
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 03-11-2015, 06:48 PM   #1252
shoman24v's Avatar
Trader Rating: 14 (100%+)
Does anyone know how to get my Flow Works Team to disable Mode 3 (torque timing) to 0? It has settings that include the set light blinking from 1-5, but won't disable. This causes the boost timing to only go from 1-5, not 0-10. As if an X12/X20 motor was connected.
I tried resetting the ESC, turn on controller, hold set, and turn the unit on. But the settings will not clear.
| HPI Blitz ESE | Reedy Mach 2 9.5 |Schumacher Cougar SV2 | (2) Team Associated RC10T | Shelfer/Runner | (2) Team Associated RC10T2 Shelfer/Runner | Team Losi XX & XX-T & XX-T CR Graphite Plus Shelfers | Team Losi XXX-4 Shelfer |
shoman24v is offline   Reply With Quote
Old 03-11-2015, 08:28 PM   #1253
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Thankīs in advance!
I've been running the LRP Flow Team Works in 1S with no booster for a few weeks now and not noticed an issue. The operating voltage towards the end of the run is 3.8v. This is in 17.5 with a Sanwa/Airtronics 471 and Futaba 9650 servo.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 03-13-2015, 10:03 AM   #1254
JDJamminX1's Avatar
Do you know what software is installed?
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 03-14-2015, 11:14 AM   #1255
shoman24v's Avatar
No idea how to find that? But it says that it has software for stock and modified classes on the box.
Incl.
Boost 0
NO. 80970
Old 03-14-2015, 06:57 PM   #1256
JDJamminX1's Avatar
Incl.
Boost 0
NO. 80970
If you have the purchased this new unsealed then it will be 1.4 factory software. Then you should be able to disable torque timing.
But is sounds like this is used and unless the previous owner can tell you, you might be on different software.
I would consider purchasing a USB bridge so that you can check what you have and take advantage of all the new software that has been released in the past few months.
Old 03-14-2015, 07:26 PM   #1257
shoman24v's Avatar
Ok, I figured that. I'll get the USB bridge. I have 5 LRP ESC's anyway lol.
Old 03-15-2015, 12:16 AM   #1258
Whats the best fix? LRP Flow
AZJWolf is offline   Reply With Quote
Old 03-15-2015, 07:50 AM   #1259
Trader Rating: 9 (91%+)
Just one thought that went through my mind.
When the pro drivers post their ESC setups, is there an implicit assumption that the brake settings on the transmitter are all set to max 80% like what the manual advise? Or should we assume they are at 100% brake EPA instead?
leongkc is offline   Reply With Quote
Old 03-15-2015, 07:56 AM   #1260
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Order the LRP worlds cap pack and heatshrink it black.
RC10-B6d | RC8-B3e
SmacTrac ~ St.Louis Dirtburners
#WeAreAE #ReedyPowered
Trevor Williams is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
