Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 12-16-2014, 04:31 AM   #1171
Salkin's Avatar
I can't see he is running in blinky mode.
If he runs with timing and boost, but with mod software with less timing and boost options, and if the others at the track runs fully timed and boosted, he would be limited in speed and punch.
Assuming he is not running blinky...
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 12-16-2014, 05:43 AM   #1172
He is running blinky
garnham is offline   Reply With Quote
Old 12-16-2014, 08:14 AM   #1173
geeunit1014's Avatar
Prodriver, imo the D4 is not a very good motor, it seems the only way to get a fast one is be on the trinity team...
Team Powers is what I would suggest. LRP motor.would be good for boosted but not for blinky..
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 12-16-2014, 08:23 AM   #1174
Everyone was raving how good it was.. Lol. Does the team rotor make a big difference people are saying the team one has upto 20% more power....?
prodriver is offline   Reply With Quote
Old 12-16-2014, 08:35 AM   #1175
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No one has had any luck with a D4 that I know of, in our neighborhood
The X20 though, lots of fast guys running them, maybe they just work better on belt & DD cars
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-16-2014, 09:17 AM   #1176
JDJamminX1's Avatar
I would suggest going to the 5.4 stock software. This has more initial drive setting (punch) then previous software. Also a new X stock break feature.
Also you have to look at the full list of mods and equipment used in stock. What are these guys doing with there batteries, chassis, motors, ETC. Stock is very competitive right now due to all the added "tuning" drivers are doing.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 12-16-2014, 09:29 AM   #1177
DesertRat's Avatar
If someone were to buy a new LRP Flow, what firmware does it come with and is it actually worth it to update? Mine seems to work just fine straight out of the box.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-16-2014, 10:34 AM   #1178
JDJamminX1's Avatar
The software that comes out of the box is 1.4. This is a good starter everyday software, proven to work.
But if you want the best then changing the software is always beneficial. The software that is offered is tailored made for the class of driver that you are. It is tested by the pros and then given to you the consumer.
Also if you are in the market for a new FLOW. At LRP-america.com, we offer your choose of software to use. No having to get a upgrade bridge. Just pick which one you want and we will install it for you FREE.
http://www.lrp-americastore.com/flow...speed-control/
Use the drop down above the add to cart button. That easy.
Old 12-17-2014, 03:09 AM   #1179
nerdling's Avatar
Regards the motor question, running blink 13.5.
D4 with around 45deg gives similar performance to a D3.5, you can then run similar gearing and get similar performance to a D3.5.
A couple of guys have tried the X20, tended to over heat when geared to a point where it was on the pace.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 12-17-2014, 08:37 AM   #1180
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I'm using 5.4 but I think the improvements see is not in the punch, it's in the brakes. 1.4 is perfectly fine.
Racing4Evo is offline   Reply With Quote
Old 12-17-2014, 12:17 PM   #1181
Can anyone explain what Torque Timing really does? In detail?
-Mike
Old 12-17-2014, 12:58 PM   #1182
JDJamminX1's Avatar
-Mike
Torque timing should me have been called torque reducer. It limits the amount of initial torque from the X20 motors. The higher the value the less torque you will receive through the RPM range.
You can further the torque feel when replacing the X20 12.5mm standard rotor with a 12mm rotor.
This feature is on able to work when using the FLOW esc with a LRP X20 motor. It is not used in stock racing and will turn off your blinky function if used.
Old 12-17-2014, 01:07 PM   #1183
Magnet Top's Avatar
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 12-17-2014, 05:01 PM   #1184
Oooh. So, if I'm feeling like my motor is too punchy, and I want a smoother feel, I should try maxing the torque timing?
-Mike
Old 12-19-2014, 03:23 PM   #1185
Jethroz's Avatar
Trader Rating: 49 (100%+)
Many thanks to LRP for releasing a firmware with reverse! (ver 1.5 w/ reverse!)
JustRacin'
"Shut up and Drive!"
Jethroz is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
