Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 11-14-2014, 05:41 PM   #1141
Nat Maniac's Avatar
Originally Posted by RedBullFiXX View Post
Also, check leads at the capacitor base
Had one of those crack one time, hidden under heatshrink, not easy to catch
Brakes on LRP's are normally lethal, even with oem firmware
I'll definitely take a closer look at the leads, but if I'm getting strong brakes holding the car in my hand would that not be affected if the leads to theccapacitor were not connected correctly?
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 11-15-2014, 06:03 PM   #1142
Nat Maniac's Avatar
Here are some close up pics of the capacitor leads, seems ok to me. There are some kinks in the leads caused by the angle required to mount the capacitor on the B5M, who knows if there are broken inside...
New LRP Flow Esc-fwt1.jpg   New LRP Flow Esc-fwt2.jpg   New LRP Flow Esc-fwt3.jpg
Old 11-17-2014, 03:42 PM   #1143
Graham11's Avatar
Trader Rating: 21 (100%+)
Having same issue, no brakes basically. Rolls to a stop.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 11-18-2014, 02:20 PM   #1144
Nat Maniac's Avatar
Mines gone back to the retailer who will perform some initial analysis then they said it would go to LRP for full testing. As soon as I get a response on what the problem is/was ill let you know
Old 11-19-2014, 03:03 AM   #1145
Nat Maniac's Avatar
Just thought id let everyone know that i put a new novak gtb3 esc in the buggy and still the same issue...tried my other almost new motor...still the same issue.
Im going to call the retailer and ask them to send it back to me. I still cant figure out what the problem is. Changed motors, sensor cables...bloody mistery
going to take it to the track on Friday and get a few other opinions
perhaps user issue!?!?
Old 11-19-2014, 04:03 AM   #1146
Salkin's Avatar
Have you checked your transmitter? Reset it, rebind, re-calibrate to esc?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 11-19-2014, 06:32 AM   #1147
Nat Maniac how loose is your slipper? i have found before a real loose slipper can be the cause of bad brakes....
Smartypants is offline   Reply With Quote
Old 11-19-2014, 05:54 PM   #1148
I don't have off-road experience, so I could be way off.
Before I went full mod in my TC, I ran a 10.5 with a healthy dose of boost with a 6.5 FDR (on the low side) with a Viper. The power was fine, but brakes were garbage. Going up to a 7.5 FDR gave me far better braking performance.
-Mike
Old 12-02-2014, 10:15 PM   #1149
jdawg81's Avatar
I have a Nosram Comet Evo which I believe is identical to the LRP Flow. It seemed to work fine with my 21.5 R1 Wurks motor until I reach around 70-100% throttle input. I'm not sure how to describe the problem but the motor seems to be cogging a bit as I go back and forth between 70-100% throttle input. In some cases the motor even slows down at full throttle. I've changed the sensor wire and I'm running the ESC in blinky mode with no timing. Has anyone else experienced this issue with this motor and how to fix it?
jdawg81 is offline   Reply With Quote
Old 12-02-2014, 10:51 PM   #1150
EDWARD2003's Avatar
What's your timing settings on your R1 21.5?
EDWARD2003 is offline   Reply With Quote
Old 12-02-2014, 11:12 PM   #1151
jdawg81's Avatar
It's at 30 degrees. I have tried different timing settings on the motor and the only time it seems to work ok is at zero timing.
Old 12-02-2014, 11:17 PM   #1152
EDWARD2003's Avatar
https://m.youtube.com/watch?v=MzE39EdYvnc
This video might be of use when it comes to setting the R1's timing.
Old 12-02-2014, 11:45 PM   #1153
jdawg81's Avatar
Thanks for the link to the video. Unfortunately it did not help with solving this issue as it does it at all timing settings. I soldered an Orca RX2 motor to the ESC and noticed it does the same thing so I think it's an issue with the ESC and not the motor.
Old 12-03-2014, 09:10 AM   #1154
Thanks for the link, nice video. It shows similar readings to the motolyser.. but there are unsolved mysteries regarding the R1 motor still..
teardown and comparison between timing readings of a killshot and R1
torg is offline   Reply With Quote
Old 12-03-2014, 02:39 PM   #1155
Default Update of Flow software om WIN 8.1 PC
Dear Friends
Anyone to help ... cant install driver for usb-bridge ver.2 ... WIN says it has to be certified by LRP, and it isn't. Any posibilities to install driver another way.
When I open the software and connect to the esc, and click ok, the program shuts Down (it does it also on a WIN 8.0 PC with the driver installed) ... any suggestions?
For your orientation, the program is runned in administrator mode, and the profiles on the PC has got assigned the rights to run the program also.
Best wishes; Jens
jensroland is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
