Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 11-09-2014, 09:09 AM   #1126
Jochim_18's Avatar
What's the advantage of the new software running on blinky mode? I still use the old software on mine and it was awesome on 17.5 stock blinky TC..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-09-2014, 12:10 PM   #1127
geeunit1014's Avatar
The new brakes have a much better feeling to me, thats the biggest difference for me
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-09-2014, 04:24 PM   #1128
chasingthepack's Avatar
coming from an orion r10 in tc the lrp brakes are 10 times stronger and smooth too
now if only i new how to set it up at the track i might have done better
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 11-10-2014, 06:01 AM   #1129
Also much finer adjustments on drag/initial brake and much higher initial drive possibilities.
cplus is offline   Reply With Quote
Old 11-14-2014, 02:03 AM   #1130
Nat Maniac's Avatar
No brakes.
Running off road 6.5t on carpet and at the end of the straight have almost no brakes. Coasts a good 5 meters before slowing down. stock settings out of the box apart from drag brake 5.
Transmitter is standard, no exp etc.
Has anyone experienced this?
Seems as though over a certain rpm brakes are applied at 10%
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 11-14-2014, 08:03 AM   #1131
Originally Posted by Nat Maniac View Post
No brakes.
Have you tried recalibrating the esc? Is this a new problem or has it always been like that?
Mike Gee
Old 11-14-2014, 08:42 AM   #1132
metalnut's Avatar
Trader Rating: 36 (100%+)
No brakes.
Your capacitor(s) may be bad or not soldered on correctly, double check that.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 11-14-2014, 12:48 PM   #1133
Nat Maniac's Avatar
yep, reset all data on my TX, then re-calibrated, still the same frustrating problem.
Ive run the esc about 4 times in stock 17.5t and cant recall any issues, I then ran an 8.5t, still cant recall this being a problem, i ran an 8.5t last week seeming no issues that I can recall (surely I would have noticed right!?!) last night I had a new 6.5t, surely the motor cant be the issue? I run all LRP X20 motors...
Old 11-14-2014, 12:51 PM   #1134
Nat Maniac's Avatar
Just checked that, it appears to be soldered correctly, its very frustrating watching cars passing me through these corners!
Old 11-14-2014, 01:10 PM   #1135
Nat Maniac's Avatar
Whats bazaar is that if I hold the car in my hand give it full throttle for 2 seconds then apply full brake it stops rock solid. I have new tyres so i cant imagine i'm sliding in a straight line.
Cant understand why its not translating onto the track..
Old 11-14-2014, 01:19 PM   #1136
Trader Rating: 15 (100%+)
When you are braking while holding the car in-hand, the only thing acting against the braking force from the motor is the rotating mass of the wheels/tires. When the car is in motion, you have another ~1400g of forward momentum that you are trying to slow down.
Are your throttle and brake endpoints set to 100% when you are calibrating the speedo to your radio?
What gearing with the 6.5t? And can you give us the software version you are using along?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-14-2014, 01:26 PM   #1137
Nat Maniac's Avatar
good point!
Yes after resetting the TX i checked to see that the end points were 100%. I run 22 pinion with 81 Spur. I dont actually know the software, I guess I can only check that with a bridge?
Old 11-14-2014, 01:32 PM   #1138
good point!
If youve never updated it you would still be on the 1.4 firmware. Maybe it would be good to try updating to v4.7 or v5.4, the brakes are something that has changed in these updates. If your running mod i would reccomend v4.7
Mike Gee
Old 11-14-2014, 02:06 PM   #1139
Nat Maniac's Avatar
Thanks for the advice, ill grab a bridge and update. Bit annoying as the one I have in my other car (b44.2) stops it on a dime!
Something doesn't seem right.
Old 11-14-2014, 02:24 PM   #1140
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Also, check leads at the capacitor base
Had one of those crack one time, hidden under heatshrink, not easy to catch
Brakes on LRP's are normally lethal, even with oem firmware
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12531 05-24-2017 01:41 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
