Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 11-05-2014, 07:33 PM   #1111
geeunit1014's Avatar
Originally Posted by ali_g View Post
hi guys,
Care to recommend setting for blinky for 13.5T motor?
Appreciate your help
At IIC I ran 2 drag brake and 2 initial drive on v5.0 firmware. Gearing and timing will depend on the motor, I ran a team powers actinium, 4.4FDR and max timing for that motor. Qualified 3rd finished 2nd
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-05-2014, 07:47 PM   #1112
ali_g's Avatar
Thank you for the info!!
I'm running the same motor. Did you use the Team Power powercap?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 11-05-2014, 09:01 PM   #1113
For blinky (on asphalt for me) it's all about maintaining speed - so drag brake and initial brake as low as possible and punch as high as you can tolerate from a grip point of view.
The new v5.4 has more low setting granularity for the brakes especially. And more punch availabLe too actually.
cplus is offline   Reply With Quote
Old 11-06-2014, 06:19 AM   #1114
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by Shock Tower View Post
Does anyone knows where I can find the V5.0 software for the works flow ? It is not at the LRP site, and has been switch out with the V5.4.
But I tried to run the V5.4 this weekend in Boosted race 17.5, and could not realy get my flow to run like when I had the V5.0 software installed.
It seems like the esc went into blinky mode on the straight, and then gained more speed in lower rpm when going around coners and chicanes.
So i am lookning to have the old software version installed again.
the 5.0 should still be in you pc. all of the software that I have loaded in my flow is still in mine, I can go back and load any of them I want to.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 11-06-2014, 07:18 AM   #1115
No, stock cap that comes with the esc
Mike Gee
Old 11-06-2014, 02:40 PM   #1116
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Anyone have a starting point FDR/Rollout for a works flow & x20 13.5 blinky???
Many thanks in advance...
Brokin Racing is offline   Reply With Quote
Old 11-06-2014, 03:35 PM   #1117
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Post
Depends on the track
27* 93mm for our club track
35* 95mm at IIC last month
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-07-2014, 08:19 AM   #1118
Looking for some thoughts on this issue. If anyone has some thoughts about the below issue, please let me know.
I tried to apply all the settings from the V5.0 setup, to the new V5.4, but it just didn't have any of the same speed as the old version.
Could it be that there is some boost settings etc.mthat might be to high on the new software, making the esc go into blinky mode periodically ?
Shock Tower is offline   Reply With Quote
Old 11-07-2014, 08:55 AM   #1119
The boost settings are all completely different on 5.4 so there isnt really a way to run your old setup. The best advice i can give is try to start in the middle for timing and ramp, and work your way to a sweet spot. Double check your sensor cable and motor sensor to make sure those arent causing problems
Mike Gee
Old 11-08-2014, 06:04 PM   #1120
EvaldasD's Avatar
Maybe someone could help. Loaded the new 5.4 firmware on Flow WT. Speedo freezes after applying throttle and do not respond, to brakes or throttle. With other firmwares this never happened. Using with X12 17.5T. And yes, I recalibrate speedo everytime after loading different firmware.
P.S. Servo works no problem, even when speedo freezes.
Any advice?
Hot Bodies - HPI - LRP - Sanwa
EvaldasD is offline   Reply With Quote
Old 11-08-2014, 08:02 PM   #1121
Try loading the software on again, and make sure to do the factory reset before re calibrating endpoints. I put 5.4 on my car today and it was dialed for blinky, the x stock brakes are nice
Mike Gee
Old 11-08-2014, 10:29 PM   #1122
nerdling's Avatar
Any advice?
I had this happen today. I reapplied the new Firmware and it came good.
Any one noticed problems with finding neutral with 5.4?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-09-2014, 01:39 AM   #1123
Any advice?
That also happen twice for me. And I did make the factory reset after installing the new software. Glad to hear that im not the only one there has had the problem.
Old 11-09-2014, 04:51 AM   #1124
Trader Rating: 23 (100%+)
This happened on both my Flow's. I just turned it on and off a few times, recalibrated and reset the settings and eventually it worked. No idea what was wrong with it. Steering worked fine but speedo just didn't wanna move.
Any advice?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 11-09-2014, 06:28 AM   #1125
EvaldasD's Avatar
Thanks a lot! After factory reset it works perfectly.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
