Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 10-17-2014, 05:21 AM   #1096
Salkin's Avatar
It runs with the 30 deg. fixed timing motor end cover.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 10-20-2014, 08:50 AM   #1097
reg
I ran the flow and 13.5 X20 in the blinky class yesterday,
I ran the 5.0 because I didn't get time to update it,and ran 35deg motor timing and max initial drive,the hottest it came off was under 70c so well happy as I had plenty of drive and top speed
reg is offline   Reply With Quote
Old 10-21-2014, 11:41 AM   #1098
reg
With the new 5.4 it shows the stock settings apart from the boost timing,do you keep the boost timing and ramp close to each other in terms of degrees?
Old 10-23-2014, 09:16 AM   #1099
MeBeMikey's Avatar
The way iv worked with the flow speedo in the past.
Say you're putting 40 degrees of boost in and the ramp is set at 20 degrees. 20 degrees is applied for every 10k RPM of the motor. So at 20K RPM all of the 40 degrees of boost gets applied. That's if you are geared correctly to hit 20k on your track size.
But, I do not know the point at which the ESC starts to apply it's boost. It use to be around 5k. So if the boost is started at 5k would then at 25K it would be where the boost would finish applying the 40 degrees of boost.
Can someone confirm my way of thinking? I don't see a start rpm for the boost in the new firmware. I wonder if it's algorithm actually starts the boost off soft in the first 10k?
MeBeMikey is offline   Reply With Quote
Old 10-24-2014, 01:10 AM   #1100
Suspended
Os their like a program box or card for this esc?
nene_805 is offline   Reply With Quote
Old 10-24-2014, 01:24 AM   #1101
Just a USB bridge to download new firmware.
Not for programming settings.
cplus is offline   Reply With Quote
Old 10-24-2014, 06:32 AM   #1102
Trader Rating: 23 (100%+)
Running in 21.5 blinky with v5.4. I tried x-stock brakes and BD3 brakes, can't really tell the difference really... anybody notice the difference?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-24-2014, 07:00 AM   #1103
Trader Rating: 15 (100%+)
Some information about LRP from ISTC/12th Worlds, if anyone is interested:
http://www.lrp.cc/en/news/news/news/...e0a2685a3aa944
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 10-24-2014, 02:53 PM   #1104
Originally Posted by cplus View Post
From this.....
To this.....!
Not my best effort....
I am being thick,what did not doing the resets do to blow the rotor?
Not sure. But it is the only thing (the firmware) that has been changed in quite a while, and they warn you that it needs to be done.
It may just have been that when I thought I was pulling a small bit of throttle for the Rev in the pits it was actually a lot and the unloaded RPM went through the roof??
What ever it was, it was catastrophic.
I've ordered a new motor and will update the ESC again and go through the steps properly this time. If that leads to a lunched motor, it will be on LRPs dime and not mine!!
so i know the answer now....
i didn't do a factory reset (or a recalibrate). The latter wasn't an issue, however, what it appears to have done is taken the "default" setting number for the previous firmware i had on board, but applied it to the new firmware.
when you do the reset, it applies the new defaults.....
going through the settings it was then,
torque timing 10deg
boost timing 30deg
Boost ramp 14deg
so with 37.5deg insert on board with the motor, yeah, umm, that'll do it.....!
Old 10-28-2014, 09:29 AM   #1105
reg
^ thanks for the info!have you had a better time second time round?
On the SXX with the new updates board fitted,what updates can I put on it?
Is it like the flow were I can put different profiles on or am I just stuck with what's already on it?
Old 10-28-2014, 12:51 PM   #1106
Yep, new motor in (trinity D4) re updated the firmware for good measure then did a factory reset and recalibrated.
Double checked all the settings were right, changing one (initial drive up), and it ran flawless.
The D4 definitely likes some timing on the end bell!!
Myself and another racer were both running brand new motors and both ended up at 60deg end bell by the close of the day!
Old 11-04-2014, 11:36 AM   #1107
Does anyone knows where I can find the V5.0 software for the works flow ? It is not at the LRP site, and has been switch out with the V5.4.
But I tried to run the V5.4 this weekend in Boosted race 17.5, and could not realy get my flow to run like when I had the V5.0 software installed.
It seems like the esc went into blinky mode on the straight, and then gained more speed in lower rpm when going around coners and chicanes.
So i am lookning to have the old software version installed again.
Shock Tower is offline   Reply With Quote
Old 11-05-2014, 05:26 PM   #1108
ali_g's Avatar
hi guys,
Care to recommend setting for blinky for 13.5T motor?
Appreciate your help
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 11-05-2014, 07:05 PM   #1109
Which firmware you running?
Old 11-05-2014, 07:32 PM   #1110
ali_g's Avatar
the default firmware.. should be ver 5.0?
☆ JU.C RACING ☆
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
