Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 10-12-2014, 07:47 PM   #1081
Hmmm. I just had my flow updated to the new 5.4 for my TC. Set it to Blinky for my 13.5t, and surprised that the brakes are much more progressive as compared to before, thus I need to brake in a bit earlier, and can meter the corners slightly fast by blipping the throttle while cornering. All in all, my esc and x12 motorare very cool to the touch after a 10mins practice run. FDR is around 6.2 currently.
Anyone got a good recommendation for the FDR on Blinky mode for 13.5 on the new firmware.
viktozzz is offline   Reply With Quote
Old 10-13-2014, 03:57 PM   #1082
How much timing do you have on the motor?
Schumacher RcHouse Racing Team
Schumacher Mi6
www.rchouse.dk
KILDK is offline   Reply With Quote
Old 10-13-2014, 08:23 PM   #1083
nerdling's Avatar
Does ROAR need to approve the new Firmware before it can be used in competition?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 10-13-2014, 09:22 PM   #1084
I have a comp flow and an x20 21.5 in my car and I seem to have what sounds like a misfire. Motor and speedy are brand new, have tried new receiver, sensor cable and even sensor in the motor.
Any ideas?
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 10-14-2014, 02:26 AM   #1085
the x12 motor is on stock insert, which should be retard timing, i believe.
was thinking of setting it to the neutral settings.
Old 10-14-2014, 05:14 AM   #1086
6.2 is a bit high for 13.5 and no timing.
In the 4's is pretty typical.
cplus is offline   Reply With Quote
Old 10-14-2014, 06:23 AM   #1087
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Fyi ...
LRP-X 12 series timing info
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
You read the timing with the dots facing you.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-14-2014, 09:06 AM   #1088
yumlailai's Avatar
I'm running 17.5 blinky, Flow with D4 combo. V5.0 firmware. It seems like I do not have enough torque coming out of corner while straight line speed is about the same as other cars. I'm gearing it at 4.04 FRD.
Thank you
yumlailai is offline   Reply With Quote
Old 10-14-2014, 09:18 AM   #1089
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Thank you
Try 5.4?
https://www.lrp.cc/en/service/softwa...ate/?file=9876
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-14-2014, 11:36 AM   #1090
yumlailai's Avatar
Originally Posted by R3VoLuTiOn View Post
I think it is more for boosted class?
Old 10-14-2014, 12:28 PM   #1091
reg
I'm giving 13.5 blinky ago this weekend,we have to run 4.50 FDR and I'm going to try 35deg motor timing on the X20,
I'm sticking with 5.0 on the speed so fingers crossed all goes well
reg is offline   Reply With Quote
Old 10-14-2014, 02:03 PM   #1092
It's for blinky as well. The big changes to the firmware - more punch, less brakes, finer braking essentially - is all about maintaining corner speed and smoothness. Exactly what blinky needs.
Old 10-15-2014, 01:32 AM   #1093
Keep us posted on this, will be interested to hear where you end up.
Cheers
Smartypants is offline   Reply With Quote
Old 10-16-2014, 11:52 PM   #1094
Salkin's Avatar
Just replaced my X20 4.5T with an X12 13.5T (on a Flow Works Team esc) to try stock racing. Upgraded to 5.4 firmware, ran default settings (blinky) +2 on initial drive and a tad drag brake, geared 4.5 (the recommended gearing on our small indoor carpet track), and it runs very smooth.
Seems like I have similar power, both out of turns and on the straight than the other stock racers running a Speed Passion Reventon Stock Spec Class and 13.5T motor combo.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 10-17-2014, 05:07 AM   #1095
reg
What motor timing did you run?
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
