Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 10-07-2014, 03:27 AM   #1066
Use the default!!
Timing just go with the 37.5 (max) temps will be fine with a reasonable FDR over 6min.
I'm running that with 3.91 - 4.12 FDR and my car smokes almost everyone at my track for acceleration and top end.
cplus is offline   Reply With Quote
Old 10-07-2014, 11:12 AM   #1067
JDJamminX1's Avatar
Originally Posted by reg View Post
Awesome news,
Will they put the setups on that they used?
Or could someone let me know a good setup to use with the new update and timing insert for the 13.5 x20,I run on a medium size Tarmac track,
Regards
Goto: http://www.lrp-americastore.com/cont...apGuide-EN.pdf
The blue highlight is the stock setting and most used. Good starting point.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 10-07-2014, 11:31 AM   #1068
reg
Thanks chaps,
Cplus what spur and pinion are you using to get them figures?
JDJamminX1 thanks for the link, it shows zero boost,but does say if using boost
Don't run a total of 90 deg of timing,how close to that do you chaps run
reg is offline   Reply With Quote
Old 10-07-2014, 02:50 PM   #1069
I run 48p as my track gets a lot of rubber & debris.
I have 74&73 tooth Spurs and 32-37t pinions. 74 and 34 achieves 4.02 on my car (TRF418, 1.8 internal)
Your FDR will depend on what car you are running.
Old 10-09-2014, 05:56 AM   #1070
I see on the LRP web site that there is new firmwear (V5.4) for these ESC's What is the differance from the V4.7 firmwear ?
shrek54 is offline   Reply With Quote
Old 10-09-2014, 06:02 AM   #1071
Salkin's Avatar
5.4 for stock, 4.7 for mod.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 10-09-2014, 06:03 AM   #1072
Yep got that, but what's the change?
Old 10-09-2014, 07:00 AM   #1073
geeunit1014's Avatar
5.4 has brakes and boost timing options specific for slower motors
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-09-2014, 11:22 AM   #1074
Read back one page where I explained it.....
Old 10-09-2014, 03:36 PM   #1075
Cridd's Avatar
Trader Rating: 16 (100%+)
it is for touring car though not offroad?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 10-10-2014, 01:01 AM   #1076
it does seem to focus on on-road mostly, but they do they is for offroad and onroad in the pitch.
Old 10-11-2014, 08:36 PM   #1077
Big oops for me.
I loaded the new firmware a few days ago and then went for a run this morning, leaving all settings at default and 37.5 insert (as before)
I was thinking "wow, this is really hauling ass.....
Oh no"
Motor was sounding awful after 5-6 (quite fast!!) laps. So brought into the pits.
I was thinking, crap, default must have torque timing or some level of boost.
Nope. Neither.
Was trying to listen for some noise, with a mild rev on the bench and the thing locked up. Smoked. Dead. Crap. The whole stator is destroyed. The magnet on the stator was in many pieces all wedged inside the can. Not pretty.
I have just realised I forgot to reset to default and re-do the TX settings.
Doh! That must have been it.
So now to order a new motor for the final 2 rounds of the season. I'm tossing up between another x20 and a D4 maxzilla.
Then explaining to my wife about how annoyed with myself I am we have the best conversation about RC ever
Old 10-11-2014, 11:25 PM   #1078
From this.....
To this.....!
Not my best effort....
Old 10-12-2014, 03:44 PM   #1079
reg
I am being thick,what did not doing the resets do to blow the rotor?
Old 10-12-2014, 04:54 PM   #1080
Not sure. But it is the only thing (the firmware) that has been changed in quite a while, and they warn you that it needs to be done.
It may just have been that when I thought I was pulling a small bit of throttle for the Rev in the pits it was actually a lot and the unloaded RPM went through the roof??
What ever it was, it was catastrophic.
I've ordered a new motor and will update the ESC again and go through the steps properly this time. If that leads to a lunched motor, it will be on LRPs dime and not mine!!
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
