Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 08-07-2014, 01:29 PM   #1036
Salkin's Avatar
I have just installed a new LRP Flow Worksteam in a newly build Tamiya TRF418.
The below mentioned problem is present both in the stock 1.4 firmware and the 4.7 firmware, which I upgraded to. I did a reset after the update as instructed.
My problem is that the motor starts running slowly by itself, especially after power on or after running the motor and breaking. And when holding a steady throttle the motor revs up and down in increment steps.
I have calibrated 10 times, tried 6 different motors (LRP and other brands), 3 different sensor wires and re-binding.
I have tried to disable every timing, turbo etc. in the esc, but the problem persists.
The speedo has replaced a speed passion speedo, and everything worked (and still does) with that esc.
No doubt it is the esc. But what can cause the speedo to behave like this?
I have read about similar problems, but can't find a solution or answer to the problem.
Help is much apreciated.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 08-07-2014, 03:28 PM   #1037
peter.'s Avatar
The berlow mentioned problem is present both in the stock 1.4 firmware and the 4.7 firmware, which I upgraded to.
I have calibrated 10 times, tried 6 different motors (LRP and other brands), 3 different sensor wires.
You have mail
greetings peter
peter. is offline   Reply With Quote
Old 08-08-2014, 03:50 AM   #1038
Salkin's Avatar
Solved the problem by buying an LRP X20 motor. Works fine now.
Rationale: maybe you have another brand motor that works with the Flow, maybe you don't. To be safe, buy a LRP X20 motor.
Old 08-10-2014, 03:08 AM   #1039
Trader Rating: 54 (100%+)
Trying to find power with this esc. Was recommended this esc for stock. I have to say my other brand feels way more aggressive. This feels sluggish. I'm on the stock firmare. Added a little drag brake and that's it. Does the update help the feel for stock? Or are there parameters I'm missing. Tried upping initial feel and that made things worse. Any help appreciated
Stock TC- medium size asphalt track medium grip level
Jamison R is offline   Reply With Quote
Old 08-10-2014, 05:53 AM   #1040
hanulec's Avatar
Trader Rating: 23 (100%+)
J -- the flow works really well in stock. The only perf new firmware gives you are braking profiles. Blinky drive profiles are unchanged.
Maybe you got the wrong motor or gearing?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-10-2014, 06:16 AM   #1041
Gonna try gearing change today. Im running Actinium on timing mark 4 with a 3.6 fdr. Should I try 3.3ish? It just feels slower down the straight is my only real issue. The feel in the infield is pretty nice.
Old 08-10-2014, 12:50 PM   #1042
mark-rc's Avatar
SO, I just updated to my flow works to V3.8 for pro buggy running X20 7.5 and realised there is NO turbo timing mode! Whats the deal with that?? I love the new brake settings but No turbo? Guess I'm going to have to go back to the basic firmware..
ANSWER-RC, HB, Sworkz, X-Act, Xpert RC, Novarossi
mark-rc is offline   Reply With Quote
Old 08-10-2014, 04:30 PM   #1043
That's pretty odd, especially as the onroad one does have it.
I guess it is the "worlds" firmware, so is exactly as they ran at the worlds perhaps with no turbo?
Very odd to release it like that though.
cplus is offline   Reply With Quote
Old 08-10-2014, 05:00 PM   #1044
hanulec's Avatar
One less tooth
Make sure your at the CCW #4
Old 08-10-2014, 05:21 PM   #1045
geeunit1014's Avatar
Intial drive will make the bottom end feel a little more aggresive, but it won't change too much. I ran 3 or 4 with the stock firmware. I think a lot of times going from a punchy esc to a smooth one the smooth one will feel slow just because you dont get the power in a burst, even though it isn't. I know Manny up here yesterday ran a 3.78fdt on his Actinium on max timing with a flow, and it was plenty fast
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-15-2014, 06:22 AM   #1046
Salkin's Avatar
Using a Flow Works Team with a 6.5T LRP X20 motor in a Tamiya TRF418 on medium sized asphalt tracks, are the standard settings in the 4.7 firmware a good start or are there any obvious changes I should make to the settings?
Old 08-15-2014, 09:17 AM   #1047
Yes, the default settings are a good place to start
Mike Gee
Old 08-15-2014, 12:00 PM   #1048
Salkin's Avatar
Old 08-19-2014, 12:40 AM   #1049
Salkin's Avatar
I'm using the a Flow Works Team with an X20 6.5T motor.
Is the speedo/motor temp readout on the speedo reliable in any way?
Old 09-07-2014, 07:48 PM   #1050
Hi all,
Thinking about pairing a FLOW works with my r1wurks 17.5. From this thread i've heard that the Flow doesn't like to work as well with other brand motors. Has anybody tried this combination?
Zhangesh is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
