Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 07-23-2014, 08:25 AM   #1021
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by linkinghobby View Post
I'm running touring car 1/10 - Lipo 2s.
The esc LRP Flow with mode cut-off voltage is 6.4 volt
Can i adjust mode cut-off voltage is 7.6 volt?
... but why would you want to?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 07-23-2014, 09:10 AM   #1022
Send a message via Yahoo to linkinghobby
If voltage down to 6.4 ,pack is swell.
Good for long life is alway over 7.6 volt.
linkinghobby is offline   Reply With Quote
Old 07-23-2014, 09:13 AM   #1023
Originally Posted by cplus View Post
Not with any of the current firmware you can't.
If esc cut off voltage at 6.4v ,battery Lipo is die.
Old 07-23-2014, 11:30 AM   #1024
metalnut's Avatar
What packs are you running? I have a couple of shorty packs that I've run down to 3.2/cell many, many times (just long practice sessions), and they're still fine. If you ant to be safe, try 3.4/cell, I really don't see the need to go higher than that.
- Ricky Bobby
Old 07-23-2014, 04:18 PM   #1025
You don't get that choice.
You can choose 1S (3.2V), 2S (6.4V) or 2S LiFe (4.0V)
The most up to date firmware(s) doesn't even have that anymore from memory, it's just "always on" assume at 6.4V unless some other trickery.
cplus is offline   Reply With Quote
Old 07-23-2014, 10:06 PM   #1026
I used pack Lrp 7500 100c
What's pack do you use?
Old 07-27-2014, 12:09 PM   #1027
peter.'s Avatar
does anyone know when will lrp with a follower of the flow
peter. is offline   Reply With Quote
Old 08-03-2014, 03:11 AM   #1028
marvcat1's Avatar
Hey guys I have a LRP Team Works with an LRP 4.0 motor. I drive a T4 and would like to know what settings or gear ratio combinations is suitable? I also use a Fantom 7000mAh pack.
XRAY NT1 2015', Novarossi Keepon, Novarossi Flash P/T
Xray T4 14', LRP Flow ESC LRP X20 17.5, Savox Servo
Futaba 4PKS-R Matrix Tyres, Kosmic Fuel, protoform VRS-N
marvcat1 is offline   Reply With Quote
Old 08-03-2014, 07:55 AM   #1029
peter.'s Avatar
it depends what kind of track you ride big small
gr peter
Old 08-03-2014, 11:01 AM   #1030
trutledge83's Avatar
hello everybody I recently swapped out my flow works team in my two wheel buggy for an Orion r10 pro speed control with 160 amps current the car feels faster and has more early to mid range throttle power what is the true operating current of the flow works team I know the instructions say 400 amps per phase but the 160 amps from the Orion feels stronger can somebody please explain this
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 08-03-2014, 11:06 AM   #1031
Boost?
Awesoman is offline   Reply With Quote
Old 08-03-2014, 12:39 PM   #1032
Originally Posted by Awesoman View Post
Boost?
No boost
Old 08-03-2014, 02:16 PM   #1033
Are you or were you using a LRP motor with the flow?, tried different motors with flow but did not seem to sork wel.
YOKOMO BD7, LRP Flow, Muchmore Fleta pro, Speedpassion GT2,
Xray53 is offline   Reply With Quote
Old 08-03-2014, 08:12 PM   #1034
It does seem that the two in combination work better than when used separately most definitely.
Old 08-06-2014, 05:20 AM   #1035
Condor Speed's Avatar
Hello, Looking for a good set up for 13.5 boosted with V4.7 program on a medium asphalt size track low to medium bite. Thanks in advance.
Top photon EX 13.5 Trinity D4, Lrp Flow Works R1 Lipo
Top Photon EX 25.5 USVTA Novak Fanton Lipo
Xray NT1 Picco
Desoto Racing
RC Target
Condor Speed is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
