Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 06-15-2014, 07:38 AM   #961
Originally Posted by Voltron989 View Post
Looking for some advice. My car seems slower then it should be.
I've tried re calibrating ESC to radio(4PKSR) a bunch of times with EPA at 100 and 120 and so on. Still the car is not as fast as I think it should be.
For comparison my T4 14 with the orca VXX and orca 4.5 motor has much more top end even with a 7.98 ratio.
Heres my set up.
411 ERYX with 7.6 FDR
LRP flow works with the v4.7 software
Reedy 4.0T timing is at default 20 degrees
ESC setings are 3,2,0,1,0,6,3,6,1,2
Running on large asphalt track. Back straight is 220ft.
Car just doesn't seem fast enough. I'm trying to hit low-mid 60mph on the back straight but I'm only hitting around 57mph (clocked on radar gun) even when turning up boost and turbo higher then the above settings.
Almost feels like no turbo is being applied. It gets up to speed nicely but just doesn't have that pull at the end of the straight. Kinda falls flat for the last 1/4 of the back straight while fast cars continue to pull hard the whole way through.
Any ideas what to try? Manual says a bad cap could cause lower power, anybody have that problem? I have another LRP flow works in my 1/10 2wd Buggy I could try to see if its the ESC I just hate to swap them out only to be disappointed
If anybody has any suggestions I would really appreciate it.
Change Reedy 4.0T timing......at 38 to 40 degrees
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 06-15-2014, 08:39 AM   #962
Originally Posted by hanulec View Post
YES! DO IT NOW! If you're running blinky, your not losing out by going to the 4.7 software.
I moved to LRP ESC because of the braking power on carpet -- as I really needed the extra power to get the Awesomatix slowed down on a super tight local track -- Critters RC.
This is my first season running LRP outdoors -- previously I've run everything else . Semi-XBrake really helps me prevent wheel lock on asphalt.
I want to try BD3 again -- but haven't had the time. It provides the most direct braking...
Okay hahaha
Awesoman is offline   Reply With Quote
Old 06-15-2014, 10:30 AM   #963
geeunit1014's Avatar
I prefer the new BD3 brakes. It takes a few packs to get used to but for me it makes the low and high speed brakes feel the same which I like
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-16-2014, 08:21 AM   #964
SC Shaun's Avatar
Send a message via Skype™ to SC Shaun
do yourself a favor, remove the ESC from the car and see if you continue to have functional problems w/o it attached to the chassis. i installed a new Flow Works yesterday at the track and had similar issues. the problem was the wires were touching a metal brace on my car.
Been testing and trouble shooting it out of the car the entire time. Good idea though. But yep, isn't an installation/car isssue.
SC Shaun is offline   Reply With Quote
Old 06-16-2014, 10:17 AM   #965
Try changing the sensor wire
Old 06-20-2014, 11:10 AM   #966
MeBeMikey's Avatar
Default Torque Timing
What does it actually do to the motor mechanically?
Does it retard the motor off the start to aid in keeping temps down? Just a guess.
MeBeMikey is offline   Reply With Quote
Old 06-21-2014, 08:08 PM   #967
I have esc lrp 200a... this esc can use with orca brushless moto???
syahon is offline   Reply With Quote
Old 06-21-2014, 09:49 PM   #968
Hello
I have problèmes
When i upgrade un 4.7 it's impossible to set transporter
When dowgrade un 1.4 lt' s OK
Do you have similarité problem?
cmqm is offline   Reply With Quote
Old 06-22-2014, 01:11 AM   #969
I upgraded to 4.7 recently and had zero issues.
Uploaded new firmware, recalibrate TX and away.
cplus is offline   Reply With Quote
Old 06-24-2014, 01:12 PM   #970
Thanks i will trie tomorrow
Old 06-27-2014, 12:02 PM   #971
Trader Rating: 20 (100%+)
Originally Posted by cmqm View Post
Hello
I have problèmes
I have the same issue. I think I will try to re-flash the esc with 4.7 again and see if there is any difference.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-27-2014, 01:17 PM   #972
You have to do a factory reset after changing the software.
Hold Set and start the ESC while holding it. After that, it will work
Old 06-27-2014, 01:39 PM   #973
oldrcr's Avatar
Trader Rating: 43 (100%+)
I found this needed to be done before you turn on the ESC for the first time after doing the update. So after updating, do not turn on the ESC unless you are holding the set button at the same time, or it will not do the factory reset and you must reinstall the new firmware again, and again do a factory reset as the first action directly after loading the new firmware.
Sorry to be redundant, but it is important that the factory reset be done.
-a
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 06-27-2014, 01:39 PM   #974
OK THANKS
Old 06-27-2014, 07:20 PM   #975
-a
Thanks I will try that.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
