Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 05-03-2014, 03:31 AM   #916
Originally Posted by retro_ryan View Post
I think it might still be accelerating,hard to tell tbh. Seems ok in the infield. Do you have any suggestions on setting, or whether to gear down or increase settings?
I do run a exzes z and 472 rec so should be able to log rpm if i can work out how to do it!
I would start by gearing down a little.
Go to 30 - 31mm and see how the car feel.
On my car I run a very low roll out and it feels great.
Settings on mine is 0.5.2.5.8.5.0
Nice and punchy on infield and good top end
VBC Wildfire D06 - LRP Flow Worx & X20 17.5 Boosted
Xray X12 - LRP Flow Comp & LRP X12 10.5 Blinky
Team Associated SC10FT - LRP Flow & Trinity D3 13.5
Team Associated B4.2FT - LRP Flow & X20 17.5
JQ Products Yellow - Argus A52 .21
Charel is offline   Reply With Quote
Old 05-03-2014, 04:06 AM   #917
I started the gearing at 6.5 fdr/30.93 rollout and it was similar if not a little slower,i then kept lowering the fdr to see if it would improve and it's a touch faster but still not right.
retro_ryan is offline   Reply With Quote
Old 05-03-2014, 04:16 AM   #918
Just remember if you lower your roll out you must increase boost and angle.
Old 05-03-2014, 05:21 AM   #919
ok ,seems like i need to up the boost timing and ramp angle and raise the gearing back to fdr 6.5. thanks.
Old 05-03-2014, 06:30 PM   #920
trutledge83's Avatar
Default LRP????!!!!! Please HELP!
can someone please explain the relation of high boost setting with boost angle? like how does it works in you have a high boost setting with a low boost angle or a low boost and high angle?? Mabe a graph showing optimum boost setting to angle or how it works!!! LRP????!!!!! Please HELP!
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 05-03-2014, 06:57 PM   #921
geeunit1014's Avatar
The short way to think of it is the amount of boost is some amount of power, and the angle is the delivery. Bigger angle is more abrupt, more aggressive. Smaller angle is smoother. There's no way to really tell what is optimum, you just have to play with it and see what feels good to you. FWIW running mod, I like the default settings on the 4.7 software
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-04-2014, 11:31 AM   #922
peter.'s Avatar
what is the better choice esc the lrp flow speed or passion reventon Pro 1.1 or much more pro fléta
peter. is offline   Reply With Quote
Old 05-04-2014, 12:00 PM   #923
metalnut's Avatar
Trader Rating: 36 (100%+)
You're asking in an LRP thread... but the Flow is a great ESC, lots of people are very happy with them.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 05-09-2014, 06:12 AM   #924
Default LRP Flow Works causing cogging with other motors?
Hi guys,
Hoping someone can help.
I have an LRP Flow Works ESC in my TC and whichever motor it's combined with, when under throttle or coasting, it can randomly "cough/stutter" for a brief second. I simply cannot pinpoint the issue. Anyone else experienced this before?
An experience guy from my local club reckons it is a known issue LRP ESCs don't work well with other brands of motors. I find this hard to believe as I don't believe I'm the only one running a mixed branded combo.
My set up.
Transmitter: Spektrum DX3S
Receiver: SR301T
ESC: LRP Flow Works (ver. ??)
Motors: 13.5t Tekin Redline Gen2; 17.5T Thunder Power, 21.5T Reedy Mach2. (All very new motors)
Gearing: 36/70 (for a 21.5T)
Notes:
I've checked the sensor wire and replaced with new ones just in case.
Timing on each motor is nothing crazy, usually around 30deg.
ESC setting in blinky mode.
Any suggestions?
Thanks in advance.
Yokomo
Sanwa / Orca / Thunder Power / Trinity / R1 Wurks
Stray monkey is offline   Reply With Quote
Old 05-09-2014, 06:52 AM   #925
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
I've run LRP and flow with different motors
No issues
Make sure sensor wire is pressed all the way into the esc, other than that, not sure what to add here
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-09-2014, 06:53 AM   #926
Bill K's Avatar
Originally Posted by Stray monkey View Post
Hi guys,
Hey man, downloaded the newest modified software for my Dad this afternoon and after setting it up came across the same issue. It'd only do it after touching the throttle, when the radio was off it seemed to remain stationary. Anyway, firstly I'd make sure you've done your throttle-neutral positioning on the ESC. Simple routine initiated through holding down the 'set' button on the speedy. I'm sure you'd know. If this still fails, set neutral position whilst holding down the throttle a tiny bit, so there's no direct split point which may be causing it to stutter now. At least with this method it's tricked into being slightly on the breaks instead. May or may not work, just something that I found was a solution.
Also a quick question, I've noticed with the new firmware that there's no Li-Po safe/cutoff configuration? Is this automatically set to default (3.2v). Haven't done alot of reading, may have been mentioned here before or in the manual. Apologies if that's the case.
Cheers,
Bill.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 05-09-2014, 07:00 AM   #927
hanulec's Avatar
Trader Rating: 27 (100%+)
Hi guys,
My set up.
Receiver: SR301T
Notes:
Any suggestions?
Thanks in advance.
try less timing.
i have an R1 Works motor (17.5) w/ a ton of timing in it. it cogs off the line -- but that is the only time. if i back off the timing the cogging appears to go away.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-09-2014, 09:13 AM   #928
reg
Hi,I'm sorry to have to ask in this thread,but after going through thread I can't find the info,
What's the best update,if any as it's not listed,to run on the sxx update board kit for 13.5 boosted,
Kind regards
Mark
reg is offline   Reply With Quote
Old 05-09-2014, 09:21 PM   #929
Thanks for the feedback guys.
Yeah, I've checked the sensor cable multiple times (including in fully depressed into the socket). That wasn't the problem.
Only thing I can't do right now is figure out what firmware it's running as I don't have access to a USB bridge. Will the latest fix this problem? Or recommend a version to use for blinky/stock 13.5 to 21.5T class?
Will try with less timing tomorrow and see how we go. Hanulec, what timing are you running with the LRP that doesn't cause this cogging issue?
Could it be a receiver/transmitter compatibility problem as well? Interested to hear if anyone else out there running a similar set up to me.
If I can't solve this problem, I've got a fairly new LRP Flow Works ESC for sale or trade!
Bit disappointed after hearing its reputation as one of the best speedies on the market.
E
Yokomo
Old 05-10-2014, 02:01 AM   #930
I've only just got a flow a flow works as well.
Futaba receiver here, 13.5T and 30deg. I had some issues at first with the sensor cable not being in far enough - I was convinced it was, but a push with some needle nose tweezers fixed it up (and some new double sided tape!)
I haven't updated the firmware yet, but will soon as I've got a USB bridge.
cplus is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12541 Yesterday 05:18 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
