Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-29-2014, 11:21 AM   #901
Trader Rating: 15 (100%+)
Originally Posted by DekelzMan View Post
So just to get this straight, the Blinky mode in the new 4.7 is the same as the latest stock software but you also get the new braking options?
So as far as I am aware, the v5.0 stock firmware only has different options for running boosted classes with higher-wind motors, such as 10.5, 13.5, or 17.5. I don't believe the v5.0 stock firmware has any different options related to blinky mode. The 'stock firmware' is a little misleading, it should really say 'stock boosted' or some such, in my opinion.
In short, yes, as far as I am aware you can run the new v4.7 firmware in blinky and get the new braking options. Use the Mode 6 setting, as Dave mentioned, to put the speedo in blinky, and you should still be able to modify the braking settings.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 04-29-2014, 11:24 AM   #902
DekelzMan's Avatar
Thank You Kind Sir!
Yokomo BMAX III Yokomo YZ2 Kyosho Optima
RCTagz.com
DekelzMan is offline   Reply With Quote
Old 04-29-2014, 12:45 PM   #903
So any news when the new stock firmware will be released?
Gerrie is offline   Reply With Quote
Old 04-29-2014, 02:42 PM   #904
Jamesalex's Avatar
A new stock firmware is in the works I have been told but I was not given a release date when I asked.
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
www.hotbodiesonline.com
Jamesalex is offline   Reply With Quote
Old 04-30-2014, 12:59 AM   #905
HI IS IT POSSIBLE TO UPDATE THE NOSRAM COMET HD SPEEDO WITH THE NEW LRP FIRMWARE BECAUSE THERE IS NO NEW ONE AVAILEBLE ON THE NOSRAM HP?
THANKS FOR ANY INFO.
CLAUDE
toroloco is offline   Reply With Quote
Old 04-30-2014, 02:02 AM   #906
Cant wait to see what they have done to it.
I hope you can adjust the boost activation RPM... cause that is the thing that still bothers me...
VBC Wildfire D06 - LRP Flow Worx & X20 17.5 Boosted
Xray X12 - LRP Flow Comp & LRP X12 10.5 Blinky
Team Associated SC10FT - LRP Flow & Trinity D3 13.5
Team Associated B4.2FT - LRP Flow & X20 17.5
JQ Products Yellow - Argus A52 .21
Charel is offline   Reply With Quote
Old 04-30-2014, 05:53 AM   #907
CLAUDE
Remane the ****.lrp2 to --->> ****.nms2
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 04-30-2014, 06:31 AM   #908
Thumbs up
THANKS HIGBO
Old 04-30-2014, 08:55 AM   #909
Originally Posted by RedBullFiXX View Post
Blinky is enabled (disabled) at Mode 6 setting
thank you for your comment. I've yesterday realized that I forgot to set the torgh were still set to 10* we have to set mode 5 and 6 to zero. After that it will blink. I also thought it will be enough to set mode 6 to 0 to get blinky.
silden is offline   Reply With Quote
Old 04-30-2014, 09:19 AM   #910
syndr0me's Avatar
Trader Rating: 32 (100%+)
I was having problems with my motor doing crazy things when using a turbo delay more than 3. 3 is fine, 4 it stalls at more than 50% throttle. I tried messing with the other settings and none of that seemed to matter. Not sure if it's a bug or what. Reedy M2 6.5 motor at 20 degrees timing.
The mode 3 brakes are impressive.
syndr0me is offline   Reply With Quote
Old 05-03-2014, 01:51 AM   #911
Anyone using a x20 17.5t boosted and flow team works with 1/10 touring on carpet, rollout is 34.8 and i'm still under 40 degrees coming off after a 5min race, there is some boost but i can barely hear it, anyone with settings i can compare too,thanks
retro_ryan is offline   Reply With Quote
Old 05-03-2014, 02:43 AM   #912
Hi there.
I run the same setup x20 17.5 with flow works boosted.
What is your esc settings?
Also what is your track like cause that is a very higb roll out.
I run Asphalt by the way.
Old 05-03-2014, 03:12 AM   #913
Track is 24 by 12 meters but a fairly tight infield with a long straight. FDR is 5.78 ,rollout is 34.8,timing insert is 27.5,motor has fan, settings on Flow Team Works with 5.0 stock firmware are;
0-4-3-5-5-3-0
the motor can is coming off under 40 degrees measured with a temp gun after a 5 minute race, feels like the it has some boost but not coming in totally(can't hear it much when racing).
Old 05-03-2014, 03:25 AM   #914
0-4-3-5-5-3-0
Is your motor reaching full rpm at the end of the straight, or still accelerating?
Those setting are a little conservative.
Does the car feel dead in the infield?
Old 05-03-2014, 03:51 AM   #915
I think it might still be accelerating,hard to tell tbh. Seems ok in the infield. Do you have any suggestions on setting, or whether to gear down or increase settings?
I do run a exzes z and 472 rec so should be able to log rpm if i can work out how to do it!
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12513 02-17-2017 12:10 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 01:24 AM
