Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 04-02-2014, 08:24 AM   #856
Originally Posted by Smartypants View Post
How much motor timing have you set? if you back of the motor timing does it still have the problem?
The D3.5 is set on 10* and the KillShot on the standard 40*. I took some boost of the esc and some turbo. I took the protection off as well as the torque timing and still the same problem. Put the X20 back and it runs fine
Gerrie is offline   Reply With Quote
Old 04-02-2014, 08:58 AM   #857
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
40' sounds a bit extreme with boost added
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-02-2014, 09:25 AM   #858
geeunit1014's Avatar
Thanks to added endbell timing on the D3.5, id guess those are actually pretty close, and reasonable, killshots run 55-60* for blinky.
I had a similar issues with a non LRP mod motor running boost, I changed the motor's sensor board and it went away.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-02-2014, 11:03 AM   #859
Can it be sensor boards on two motors. The d3.5 ran perfect a week ago on a friends HW, and the KillShot on a SP esc.
Old 04-02-2014, 11:06 AM   #860
I run my X20 with the 32.5* insert and even tried it with 35* insert and it was fine
Old 04-03-2014, 08:39 AM   #861
Hard to say, that was just my experience. I would also make sure since its 17.5 that the settings you are using allow the turbo to engage consistently, too much boost timing or not enough ramp and you may not get turbo all the time
Mike Gee
Old 04-03-2014, 09:15 AM   #862
Thanks. I will give it a try and let you know. ....but if the turbo/boost works on the X20, will that not be good enough for the other motors?
Old 04-03-2014, 10:17 AM   #863
It should be close, but each motor is different so they may require slightly different settings. Maybe try moving the motor timing to extremes as well and see if there is any difference
Mike Gee
Old 04-05-2014, 09:30 AM   #864
d16dcoe45's Avatar
Default more punch for blinky?
I had assumed that the Flow Works Team was the "better" ESC even for 17.5 sedan blinky, now I am wondering. I just read that the Flow Comp has more punch in blinky than the Works Team due to having fewer FETs on the board. Does someone who knows more about electronics than I do confirm if this could make sense?
Also, coming from a Viper VTX10rBE that had a large range of throttle PWM frequencies, I am wondering if anyone knows what the throttle PWM freq. is for either Comp or Works Team? I know they are not adjustable but every ESC has a frequency it operates at.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 04-05-2014, 06:52 PM   #865
I had a Flow Comp for a little while, it didnt really feel any different than the Works Team in 17.5 TC to me. Also keep in mind, even if there was a small feeling difference, the works team would likely be faster over a run due to better efficiency from the extra fets.
When I ran mini z for a while where changing the brand and number of fets is fairly common, the brand of fet and the way they switch was a much larger factor in the "punch" of a car than double stacking the same kind of fet in my experience. I would also say in my experience, a lot of times something that feels more "punchy" is not as fast than something that is smoother but more efficient..
Mike Gee
Old 04-08-2014, 12:39 PM   #866
skrichter's Avatar
Send a message via AIM to skrichter
Looking to confirm, for those of you who are running the v3.3 software, do you recieve a initial beeping noise when you are just barely squeezing the throttle? I don't remember ever hearing a noise before installing the v3.3 software (but I only ran it for a couple days before having the new software). I'm running a Reedy Mach 2 8.5.
If someone could please confirm. Thx!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 04-08-2014, 12:49 PM   #867
skrichter's Avatar
Originally Posted by Sean Cochran View Post
I think a more correct description should be "any 540 sensored motor will work with the Flow Works team."
How about 550 2pole motor? I was going to try a Reedy 4.0 550 w/LRP Works. Anyone have experience with them together?
Old 04-09-2014, 08:12 AM   #868
Hi guys. Looks like I sorted my speedo issues with D3.5 and KillShot. I restored the esc to V1.4 and reloaded V5.0. All seems to be working fine. Will check this weekend and give some feedback.
Has anyone got a good base setting for the KillShot in 17.5 boosted. My X20 melted on the inside so it is a bit sick at this stage
Old 04-13-2014, 08:39 AM   #869
reg
Hi,
I run a flow works and was wondering if I would notice any difference if I ran the comp in my wet car? I run a 13.5 x20
reg is offline   Reply With Quote
Old 04-13-2014, 10:40 AM   #870
Need some good advice from you guys, about a good base setup for a 17.5 boosted setup.
I have just purchased a LRP flow works team esc, and will run it with a Hobbywing V10 17.5T.
Is the some standard profiles loaded into the esc from the factory, or shall I create my own setup ?
If yes to making my own, could you guys then surgest a good base setup, so I don't burn my esc and motor from the beginning.
Thanks in advance.
Shock Tower is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
