Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-05-2014, 10:10 AM   #841
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by Jerry P View Post
Does anyone have a part number for the stock capacitor for the Flow?
http://www.lrp-america.com/us/produc...0-74v/details/ i see alot of guys using this
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is online now   Reply With Quote
Old 03-08-2014, 07:04 PM   #842
I am running my LRP Flow with a 1S LiPo and a Novak 1S booster. The Booster Module (#5477) does not include LiPo cutoff circuitry. When running the booster with 1S am I supposed set the LRP's cut off voltage to 3.2V or 6.4V?
rossb is offline   Reply With Quote
Old 03-08-2014, 09:01 PM   #843
Trader Rating: 15 (100%+)
3.2v or just disable the voltage cut-off altogether.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-19-2014, 12:36 AM   #844
Tossed up between a Flow Works and an R10 this week to go into a TRF418
After a fair amount of research and deliberation on hitting the checkout button, I've ordered the LRP with an X20 13.5t to run in blinky on a rather large track (they also run 1/5th scale).
Considered pairing with a D3.5 but the price on the pair plus some neater cosmetics (it matters, right?) swayed to blue.
Main pro's for the LRP over the R10 for me were;
- it's newer
- the R10 is about to be obsolete
- no program card to get the best from it
- about to get new firmware, assume for the upcoming worlds (possibly unlikely the R10 will see any as it is being replaced)
- higher voltage BEC
- lower price when combined with matching motor
- easier soldering tabs (well, looks that way to me)
Going to start with a FDR of 5.55, see how we go. I expect slowly at first.
Don't fail me LRP - this is my entry into racing after always wanting to do it as kid
cplus is offline   Reply With Quote
Old 03-19-2014, 12:57 AM   #845
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
- it's newer
Dont trust the lrp man go hobbywing,r10,speedpassion 1.1 ex,ive had two flows both failed last lrp i can remember having no issue was the lrp spx back in the day lol, what has happen to lrp?.last one failed after two meets
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 03-19-2014, 01:51 AM   #846
too late. as I said, see how we go.
there are good, bad and horrific stories out there about every brand.
Old 03-19-2014, 03:21 AM   #847
P.I.M.P's Avatar
AS much as they fail me i cant stop using them they do have a nice feel
Vbc wildfire D06
clinton livingstone
Old 03-19-2014, 03:24 AM   #848
I'm running in 13.5 boosted with X20 and flow esc anyone have a good starting point set up for the current software on a mid size track. 6 min race.
Chris kal is offline   Reply With Quote
Old 03-23-2014, 05:57 AM   #849
marvcat1's Avatar
I have a LRP competition ESC. what would happen if I use a lower turn motor lets say 4.5 modified?
XRAY NT1 2015', Novarossi Keepon, Novarossi Flash P/T
Xray T4 14', LRP Flow ESC LRP X20 17.5, Savox Servo
Futaba 4PKS-R Matrix Tyres, Kosmic Fuel, protoform VRS-N
marvcat1 is offline   Reply With Quote
Old 03-23-2014, 07:31 AM   #850
DirkW's Avatar
With a 4.5T the ESC will probably die in a little cloud of smoke sooner or later (probably sooner), as it is only rated for 9.5T
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YR-10F | Yokomo R12C3* | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Team Associated RC10R5.1 FT*
Future cars (soon): Yokomo YRX-12* | Tekno SCT410.3* | Xray X10 '16* | Yokomo YZ-2 CA | VIP-Performance Vorlon
DirkW is offline   Reply With Quote
Old 03-23-2014, 10:10 AM   #851
JDJamminX1's Avatar
The LRP Comp ESC has less fets inside which results in less amps output. A 4.5 motor would heat up the ESC too quick and over heat.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 03-30-2014, 10:01 AM   #852
reg
Hi,
What's the best firm ware to run in the Flow with X20 13.5 boosted,
I'll be running an Mi5 at West London for the BTCC,
Thanks,
Mark
reg is offline   Reply With Quote
Old 04-01-2014, 08:30 AM   #853
Hi. I have a small problem. Running my X20 17.5 in boosted all runs well. I tried a KillShot and D3.5 , and when i rev the motor , it boosts fine and then looses it. I tried sensor cable , other battery , even re-calibrated the radio and esc. Has anyone else had the same problem?
Gerrie is offline   Reply With Quote
Old 04-02-2014, 08:13 AM   #854
Originally Posted by reg View Post
Hi,
Thanks,
Mark
Version 5.0 firmware.
Smartypants is offline   Reply With Quote
Old 04-02-2014, 08:14 AM   #855
How much motor timing have you set? if you back of the motor timing does it still have the problem?
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12513 02-17-2017 12:10 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 09:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 01:24 AM
