Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 01-08-2014, 06:54 PM   #811
geeunit1014's Avatar
Originally Posted by TheRcKid17 View Post
Its there a delay reverse? can find how to do it.
There is no reverse at all. LRP racing speed controls typically dont have reverse
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 01-08-2014, 11:02 PM   #812
Cridd's Avatar
Trader Rating: 16 (100%+)
The flows don't have reverse.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-15-2014, 03:33 AM   #813
Hi folks,
I have two LRP Flow WorksTeam ESCs, and I need some help. I've changed softwere from 1.4 to 3.3 and one of them works perfectly, but the other esc after updating doesn't react to throttle, servo works fine. When i changed back to softwere 1.4 every thing started working properly. The updating process was done without any problem, also i'm not newbe to this ESC. Of course after changing soft I've recalibrated radio. Anyone got an idea?
Schumacher Cougar KF2 | LRP |
Schumacher CAT K1 Aero | LRP |
Schumacher Cougar KF | LRP |
_______________________________
TitanRC.pl - Schumacher Poland
K.Chmura is offline   Reply With Quote
Old 01-15-2014, 03:46 AM   #814
Did you do a reset as stated after the updates?
VBC Wildfire D06 - LRP Flow Worx & X20 17.5 Boosted
Xray X12 - LRP Flow Comp & LRP X12 10.5 Blinky
Team Associated SC10FT - LRP Flow & Trinity D3 13.5
Team Associated B4.2FT - LRP Flow & X20 17.5
JQ Products Yellow - Argus A52 .21
Charel is offline   Reply With Quote
Old 01-15-2014, 04:34 AM   #815
Trader Rating: 18 (100%+)
My son wanted to plug the battery while i was looking away, he inversed + and - as banana plugs are used on my esc...
Results: undesired sound, big spark, little smoke, itchy fingers and a car that don't run.
Turning on the switch steering and both fans running plus a nice double blinky ESC (twice legal for GT2 !!)
Seriously, I have the LRP Flow Esc and I have blue and green leds flashing showing that it would be a battery voltage or cutoff issue. Changed the battery for other one and same results.
I was suggested to remove capacitor but now I have 3 lights blinking...
Is it the end of my Esc's life ?
thejo3 is online now   Reply With Quote
Old 01-15-2014, 04:36 AM   #816
Yes I did, as I said one esc works perfect with both soft version 1.4 and 3.3, but the other one works only with softwere ver 1.4, i've done the updating process and reset properly. I repeated this 3 times but i gave up.
The one that doesn't work with soft 3.3 i have received from LRP on warranty after i had burned my earlier flow esc, it's almost unused.
Old 01-15-2014, 04:47 AM   #817
Jerry P's Avatar
Trader Rating: 44 (100%+)
Did you change the capacitor or just remove it?
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-15-2014, 04:59 AM   #818
Removed.
Should I plug one in the receiver or solder a new one on the esc, if so, what part # would be enough for that esc ?
Old 01-15-2014, 05:06 AM   #819
Jerry P's Avatar
Removed.
I always run the capacitor on my Flow so i dont know how it would react without one. Do you have another lrp capacitor you could put on there?
Jerry P
Old 01-15-2014, 06:40 AM   #820
Yes, I could try another one tonight.
Old 01-15-2014, 08:45 PM   #821
Cridd's Avatar
Try new cap, flash software to version you had if you can. If that doesn't work it is toast.
Chris
B6D / T5M / SC5M
Old 01-16-2014, 06:45 AM   #822
swarf's Avatar
My Flow was awsum. Then it just stopped working. It coasted to a stop in the middle of a race flashing a "locked rotor" error code. Sent it back to LRP (still under 90 day warranty). Waiting. Using this terrible 90a xerun. It's so slow it's depressing
It's my buggy and I'll drive if I want to
You would drive too if it happened to you
swarf is offline   Reply With Quote
Old 01-20-2014, 05:12 AM   #823
So I had another Flow ESC, removed the capacitor from car #2 and tried the car and it worked withtout the cap.
Soldered the cap on car #1 and nothing, try different motor, nothing, try different sensor wire, nothing. Fan works, servo works so power runs okay, but wheels doesn't move.
Re-setup the esc, nothing.
So how do I flash the software now ?
Old 01-21-2014, 12:58 PM   #824
peter.'s Avatar
and what is the better choice lrp flow workse team or hobby wing v3.1
peter. is offline   Reply With Quote
Old 01-21-2014, 01:45 PM   #825
chasingthepack's Avatar
neither get an orion r10 pro,ive had mine at the top in blinky and13.5 boosted,cant fault it
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
