Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 12-03-2013, 09:18 PM   #781
testcrashdummy's Avatar
Originally Posted by LloydLoar View Post
With a 17.5 and maybe even a 13.5 you might be able to get the Flow to work without a voltage booster or rx pack. If you run anything faster than that you will likely encounter issues.
Okay, so power dropping out with no RX pack is a known issue?
I just ran a brand new Flow for the first time - practiced with a Tekin Gen2 and didn't have any issues. Then, a week later, I switched to a D3.5 17.5 before a race (also replaced all the wires at that time to black) and started experiencing power dropouts - both steering and throttle would just go dead for a moment, then the car would come back to life. All of the new wires were soldered in cleanly (but maybe the board got too hot from soldering? I dunno, just trying to think of what could have happened).
At first I thought it was a glitch or radio issue, swapped RXs, still had the same problem. Then I tried an RX pack and it seemed less frequent, but it was still dropping out. Next, I replaced the ESC power harness thinking maybe the plug was bad - still had the same issue. Finally, I threw in another ESC and no more issues.
Only thing I haven't done is open up the ESC to ensure the harness wires are well-soldered. Anyhow, should I just send it back to LRP and ask them to test it? I can't trust it.
testcrashdummy is offline   Reply With Quote
Old 12-03-2013, 09:47 PM   #782
If its still acting up after you used a Rx pack then the problem is most likely the fact that you accidently de-soldered something or worst (burn) while you were soldering?
Charel is offline   Reply With Quote
Old 12-06-2013, 06:39 AM   #783
bigcracing's Avatar
Trader Rating: 32 (100%+)
I have a flow and at the last race when I would plug in my RX pack the speedo would go to a solid red lite. I replaced the sensor wire and it would correct the problem for a short time then come back when I would turn it on it would go solid red again. It seemed to be a intermittent problem. I tried switching out recievers and battery packs and RX packs still same problem. Any suggestions?
Thanks Chris
bigcracing is offline   Reply With Quote
Old 12-06-2013, 01:04 PM   #784
Thanks Chris
Is your switch in the off position with the Rx pack? I'm sure I've read somewhere that it has to be off..?
I could also be totally wrong
VBC Wildfire D06 - LRP Flow Worx & X20 17.5 Boosted
Xray X12 - LRP Flow Comp & LRP X12 10.5 Blinky
Team Associated SC10FT - LRP Flow & Trinity D3 13.5
Team Associated B4.2FT - LRP Flow & X20 17.5
JQ Products Yellow - Argus A52 .21
Old 12-06-2013, 01:13 PM   #785
There are a number of people having this issue. Some explain it as the car looses bind for a brief sec and then returns. I can tell you there were a number of people at the indoor champs with this issue including myself. It is not resolved by a booster or receiver pack. We are still trying to figure it out but no answers yet. It is also not specific to Radio mfg's or speed control mfg's.
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 12-06-2013, 01:39 PM   #786
bigcracing's Avatar
Yes switch was off Thanks
Old 12-07-2013, 01:12 PM   #787
bigcracing's Avatar
What is the difference between the flow and the flow works team.
Old 12-08-2013, 09:54 AM   #788
I don't know if this has been answered yet, but does anyone know if this ESC has reverse as well?
Kamika007z is offline   Reply With Quote
Old 12-08-2013, 10:00 AM   #789
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
It is a pure competition esc
NO reverse
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-08-2013, 10:07 AM   #790
NO reverse
Understood, thank you. One last question: One cannot be programmed if wanted right?
Thanks again RedBullFiXX. I'm new to all of this. I just added one to my RC10 Classic.
Old 12-08-2013, 10:07 AM   #791
The flow works motor limit I think is 3.5 while the regular flow motor limit is 10.5 I believe.
steve
Old 12-08-2013, 10:57 AM   #792
trutledge83's Avatar
steve
Compition : 200 amps, Works Team: 400 amps
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 12-08-2013, 10:30 PM   #793
Nope, it is like RedBullFiXX said a pure racing esc so no matter what, you dont have or can't program reverse into it.
Old 12-10-2013, 04:47 AM   #794
bigcracing's Avatar
LRP Flow comp. and plug in RX battery pack and get a solid red lite.
Any suggestions would be help full I did turn the switch on and off no changes and tried other fully charged packs and tried other sensor wires. Somtimes it goes into blinky mode blue flashing lite and then when I plug it back in I get a solid red lite.
Thanks Chris
Old 12-10-2013, 08:03 AM   #795
JDJamminX1's Avatar
Thanks Chris
Usually solid red indicates that the EPA adjustments are not set properly for the ESC to the radio.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12532 06-12-2017 04:14 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
