Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 11-19-2013, 02:19 AM   #751
Originally Posted by Troy Carter View Post
I've not run boosted 21.5 but I would gear it closer to 5.5fdr and boost up if needed. I'm thinking that you are geared too low putting stress on the ESC causing it to slow very shortly.
Thanks Troy, has anyone else ever ran 21.5T Boosted?
mrlahey is offline   Reply With Quote
Old 11-19-2013, 07:42 AM   #752
David Home's Avatar
Questions??
Anyone help me out here, running v5 with X20 13.5t motor. Tight indoor carpet track, just a baseline setting I can work from. The recommendation with the motor says to gear at 5.5:1 FDR for 13.5 TC. I just don't want to blow it up so any help at all would be appreciated
David Home is offline   Reply With Quote
Old 11-19-2013, 01:56 PM   #753
AE-Reedy
Are you running boosted or blinky?
Blinky I would start around 4.6:1 with 2 dot insert, 37.5 degree
Boost Not sure it's been a long time maybe 6.3:1 with 4 dot 27.5degree.
It really is going to depend on how you have the SC set up with the boost and ramp though.
Sean Cochran is offline   Reply With Quote
Old 11-19-2013, 02:13 PM   #754
David Home's Avatar
Hi Sean, thanks for replying, we run boosted, I have it set with the following, 2,5,4,8,7,7,3
My FDR is 8.5, the motor timing is set at 27.5 box stock. Does this look right?
Our next meeting is on Sunday so I won't really know till then when I get it down on the track. Just thought if there was anyone running the same combo could check against theirs.
Old 11-19-2013, 06:33 PM   #755
trutledge83's Avatar
DOES ANYONE KNOW IF THE LRP CAPACITOR WORKS TEAM #82531 WILL WORK WITH THE FLOW WORKS TEAM?
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 11-19-2013, 09:49 PM   #756
Your FDR seems a bit high to me but is track dependant.
Also I presume you mean 2,5,4,8,7,5,3 as there is no 7 in the turbo mode.
What firmware are you using?
How long is your main straight?
Charel is offline   Reply With Quote
Old 11-20-2013, 04:18 AM   #757
David Home's Avatar
I'm using the v5 firmware, our main straight is about 25-30m long.
Old 11-20-2013, 04:44 AM   #758
Okay,
I would start at a fdr of say 7.0 - 7.5 and go from there.
Also the std timing insert as you have with the following settings, 2,4,2,5,8,5,3 and work from there.
Pay attention to your motor on the main straight, try and listen if itís over revving or still picking up speed by the time you get to the end. And always remember to check temps every 2min.
Goodluck
Old 11-20-2013, 05:48 AM   #759
David Home's Avatar
Thumbs up
Okay,
Goodluck
Thank you for your help
Old 11-20-2013, 04:44 PM   #760
I tried the capacitor and note: the lrp works team #82531 does not work with the flow works team. When I first drove the car under breaking the steering servo would not respond. When throttle resumed the steering servo would act normal. There is some wrong signals going through the system with this capacitor on it. I reinstalled the original capacitor and it works normal.
Old 11-20-2013, 05:56 PM   #761
narcotiks's Avatar
Originally Posted by mrlahey View Post
Please offer your advice. I am running 21.5T Boosted. LRP Flow with a X12 21.5T Stock Spec. FDR is 4.0. Speed control running v5.0 with settings 0,3,3,3,6,3,3. End bell timing is horizontal insert. The problem I am having is the car slows down a bit after the first 2-3 laps, motor temp is about 75 degrees c. Any suggestions to what I have wrong?
First Put the 4 dot insert back in the motor (less motor timing).
After this, try your FDR at 4.5 , 21.5 boosted usually needs FDR between 4 to 5.
narcotiks is offline   Reply With Quote
Old 11-22-2013, 11:27 AM   #762
I could not let this capacitor go to waste. I installed it on my 22T that has the LRP SXX v2 TC Spec ESC and it works great, more punch with the throttle. I still dont know why it wont work with the Flow Works Team?? anyone know why? I see the pros using it! I called LRP and they said it should work fine with the FWT.
Old 11-23-2013, 06:16 AM   #763
Default firmware update
Can anyone please tell me how to update to the latest firmware 5.0. step by step. I have already downloaded it to my computer and I have the usb but I don't have any instructions on how to install it to my team works flow.
Chris kal is offline   Reply With Quote
Old 11-25-2013, 08:56 AM   #764
JDJamminX1's Avatar
Here is the instructions for the USB Bridge. It should have been included with your purchase.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 11-26-2013, 04:56 PM   #765
Thank you very much for your help . I got it off a friend at my rc track he had lost the instructions.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12525 03-20-2017 08:59 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
