Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 08-31-2012, 03:24 PM   #61
Thanks for the replies.
I can't figure out why the FLOW needs a receiver battery ... the SSX version 2 didn't need it, and woorked perfectly with 1S batteries. I can't see a receiver battery on several pictures from the worlds - including Ronalds car, and furthermore the presentation on the LRP site says, that it work with 3,7-7,4 volt.
I am aware of, that a receiverbattery can boost the performance a tiny, tiny bit, and ad around 8-10 sec more drivetime, if you are on the limit of enough power in the battery.
Jens
jensroland is offline   Reply With Quote
Old 08-31-2012, 04:14 PM   #62
Trader Rating: 216 (100%+)
Originally Posted by Julius View Post
As a nitro racer i need all capacity for the motor anyway so the receiver pack helps
I thought Nitros ran on fuel, not batteries!!!
Andy Koback is offline   Reply With Quote
Old 09-04-2012, 04:25 PM   #63
CnR
CnR's Avatar
Trader Rating: 31 (100%+)
I found this http://www.hrcspain.net/producto_LRP...EN-_41197.html
CnR is offline   Reply With Quote
Old 09-04-2012, 09:47 PM   #64
chevtech23's Avatar
Thats like $292 usd, lets hope the us prices comes in lower, id be suprised if it was much over $200
chevtech23 is online now   Reply With Quote
Old 09-04-2012, 10:03 PM   #65
Geberit's Avatar
This will be more likely the price .... otherwise they won't be competitive against other brands!
http://www.rc-cars24.com/index.php?c...d75c3f9ilhc504
Geberit is offline   Reply With Quote
Old 09-06-2012, 10:25 PM   #66
AE-Reedy
Jens
The SXX V2 had a special BEC that could boost the voltage to the Rx when using 1s battery. LRP identified that was the cause of many SXX failures so for the Flow they removed that type of BEC.
Ronald did have a Rx pack in his car, it was just not plain to see. All LRP racers used one at the WCs.
Sean Cochran is offline   Reply With Quote
Old 09-07-2012, 02:52 AM   #67
Sean,
Do you know or has anyone tested these in 1s boosted in any oval classes? I guess I am asking if this will compete in oval? I had an sxx stock spec V2 and it just seemed a little behind the competition. I realize that these were not designed with oval in mind but was curious if you thought it would work. Sorry to hijack the thread.
cwalsh is offline   Reply With Quote
Old 09-07-2012, 09:55 AM   #68
AE-Reedy
Originally Posted by cwalsh View Post
Sean,
No there is only a limited number of SCs that have been used for testing. We have run the Flow at the Worlds, and the past couple of Nats, off-road and on-road. The programming is much more advanced over the previous units and I would guess that it should work. I think the main problem before was no way to adjust the timing ramp, which you can do in the Flow.
Old 09-08-2012, 04:00 AM   #69
The Flow need a receiver battery.
Yes, it need a receiver battery ... all pictures of 1/12 cars you can surely see a receiver battery. Futhermore the text for the update-kit for the SXX speed-controls on the website clearly says, you need a receiver battery for it.
The text for the SXX v2 models on the website says twin-BEC and that they can boost 1s up. The upgrade-kit says BEC and that you need a receiver battery. The new FLOW also (only) says BEC, and this indicates, that the upgrade-kit and the FLOW's are based on the same architrecture ... and therefore the FLOW's also need the receiverbattery.
I and several others in Denmark have used the SXX v2 since they came out without any issues at all ... they have worked flawlessly at any time.
One of the reason that we have chosen the SXX v2 over other manufactures are the ease of use and the performance. When LRP now chose to remove the twin-BEC, we see it as a step back in the ease of use. We surely have prefered, that LRP have had chosed to develop the twin-BEC so it would became bulletproof in terms of reliability.
Several others top level manufactures have integrated step-up volt from 3.7 to 6.0 volt in their speed controls with succes, and wich therefore will be easier to use in terms of not to use a receicerbattery. But theres have not the the easy programming system that LRP have, and we all love so much.
The choise of speed control for the upcoming season has becaome a bit more difficult - the easy programming or no receiver battery? - hope much LRP will continue the development of a twin-BEC, and incorporate it in the next generation of the FLOW's - then the coise will became easy again
Best wishes; Jens
Old 09-26-2012, 10:32 PM   #70
Geberit's Avatar
When is the release date? Everything seems so quiet ...
Old 09-27-2012, 03:33 AM   #71
wtcc's Avatar
In Germany the start will be in the beginning to middle of october. Maybe this counts world wide...
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 10-21-2012, 10:37 AM   #72
Still exciting waiting for the release ... LRP said first september in august, and still nothing new.
Latest rumors said then beginning to middle of october, so it must be just around the corner - and what about the price ... down to around 149 euros for the works team version ?, or will it be a bit higher. Hopefully 25-30% lower price than the ssx versions, and certenly not up near what they are adverticed on some websites with prices up around 250 euros.
Eager to see the functions in the software, and hopefully there will be a dedicated modified optinally software with finer steps as mentioned earlier in this thread.
Jens
Old 10-21-2012, 10:52 AM   #73
steveonamission's Avatar
Says 24th... So this week
http://www.rccarshop.co.uk/index.php...pre-order.html
steveonamission is offline   Reply With Quote
Old 10-21-2012, 02:49 PM   #74
Blue Screw's Avatar
Send a message via AIM to Blue Screw
I wonder if another reason they removed the twin bec and tell u to use a rec pac or booster might be the fact that the newer servos an rec need higher voltage to see max performence? Also i remember a number of top racers still choose to run the rec batt over running it without..
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 10-22-2012, 12:47 PM   #75
Trader Rating: 3 (80%+)
If I get the upgrade on my tc spec v2 does that make it the same as a flow then? Same settings etc?
traitor is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
