Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 10-24-2013, 04:21 PM   #706
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Logi Maker View Post
Any way to tell what software is installed without hooking up to computer?
I have the LRP bridge connector and the software on my laptop, I can bring both to the gym if you want to hook up yours.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 10-24-2013, 07:26 PM   #707
Tech Legend
Wild Cherry's Avatar
JD
Esc is set to blinky mode before the install.
radio is set for 100% power/100% brake Airtronic m12
ESC neutral throttle reset done after down load.
down load looks good on computer, no red flags or error codes
Appreciate all the help
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 10-24-2013, 08:13 PM   #708
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Need HELP...
Have a brand new Flow that I wanted to update straight to V4.0 from V1.4. My mac computer crashed in the middle of the update and now the ESC no longer connects to the Updater Application. USB bridge now shows solid blue and orange light after failed connection prompt.
Can someone assist? Can I fix this without sending it in?
Racing4Evo is offline   Reply With Quote
Old 10-24-2013, 09:02 PM   #709
What if I want to hook up mine? Would you still bring it?
-Mike
Old 10-24-2013, 10:14 PM   #710
metalnut's Avatar
-Mike
Of course man I figured most of you guys already have the bridge, but if not, I'll be glad to share mine!
- Ricky Bobby
Old 10-25-2013, 06:45 AM   #711
skrichter's Avatar
Send a message via AIM to skrichter
Delete
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 10-25-2013, 06:05 PM   #712
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Thanks for the offer but wont be at the gym until the Can Am challenge.. I check it out down at the TZGP.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-27-2013, 10:34 AM   #713
trutledge83's Avatar
Default Glitch
Hello I have a Flow works team and Durring full throttle and mid throttle I can hear the motor shuttering like it is cutting power for a fraction of a second. At first I thought it was a receiver issue and changed it out but the problem is still there. I loaded different software on it and issue still present. Also tried a different motor. My gearing is what is prescribed in the manual for the 13.5t motor. No warning lights have ever been triggered except low voltage.
Any ideas!? I
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 10-27-2013, 11:06 AM   #714
[QUOTE=Bill K;12255071]Alright, im pretty unhappy with the performance of this ESC.
Ran some suggestions that were recommended for use here on this forum, and nothing was really competetive enough to use, or even to consider to use racing in a state championship.
I then clocked everything up. Had the Boost timing on option 9, activation on option 10, turbo on obtion 3 and motor timing on 40deg, and it spanked. The motor reached a total of 90deg celcius, but this can be controlled with heatsink and fan ect.
I then drove this on with other cars running tekin and Speed Passion esc's, and still, they were faster down the straight, out of the corners, when I was taking the best raceline possible for almost the full session. Although I managed to keep them behind me, I was still threatened by their faster more competetive cars.
So... What now?
Honestly.
what motor and software are you running?
Old 10-27-2013, 11:09 AM   #715
Racing4Evo's Avatar
#1 cause of motor/speed control malfunctions= broken sensor wire
Have you checked it?
Old 10-27-2013, 11:13 PM   #716
Bill K's Avatar
Any ideas!? I
I know exactly how you feel, as this very same problem occured with me and my, once, LRP setup..
I tried everything, from changing sensor wires, motors, receivers, batteries, radios, capacitors, but nothing seemed to fix the issue. Finally I came to the conclusion that this ESC had some sort of internal errors occuring inside, so I simply swapped it out for a HW v3.1. I've been running the HW with the same setup exactly as I was using with the flow when the stuttering was caused, and I have had no issues at all. I was running the v5 stock firmware, with the TP 17.5T motor with high torque rotor. Ran the same setup at the state titles held here, and no issues at all.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 10-29-2013, 03:44 AM   #717
Yes did that as well. After some testing I noticed that it was only doing this glitching on a certain part of the track and street. I started to think and my radio is older. It's an m8 with spektrum module. I think I have narrowed it to the old transmitter and the receiver loosing signal. So I purchased a mt4 just waiting on it in the mail now.
Old 10-29-2013, 06:45 AM   #718
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Exclamation LRP Warranty repair....
Anyone out there know the link to the Warranty Dept. to send my Flow out for repairs??..... Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 10-29-2013, 07:21 AM   #719
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Effective September 1, 2013, LRP America will provide all customer service and technical support for LRP. Please contact them for any questions you may have regarding your LRP product.
LRP customer service and technical support:
LRP America
927 Calle Negocio, Suite D
San Clemente, CA 92673
Phone: (949) 276-6060
Email: [email protected]
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 10-29-2013, 09:35 PM   #720
Kwikvdub's Avatar
Thumbs up
Thanks for the info Barry!
Alex Valdes
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
