Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 10-11-2013, 07:19 PM   #691
Originally Posted by metalnut View Post
I didn't realize you were running a VTX10R, Mike, that's good to know though. Therefore, I retract my previous comment, some fast guys are running Vipers
Having said that... when I was first looking for ESCs, our local guys pretty much told me to stay away from Viper based on some local drama. It sounds like those bad vibes have passed, which is good.
Actually, the viper is in my pit box. I ran it the last couple years in 17.5. Running tge flow in mod and tekin in SS.
-Mike
Old 10-18-2013, 03:38 AM   #692
trutledge83's Avatar
Originally Posted by entitymugenmtx View Post
Can somone help me with a problem that I am having with my speed control?
When I turn my car on the wheels will spin for 3 sec and stop.
i had the same problem, set your radio and reciever to your desired "no signal" settings usually brake and sterring wheels straight. spektrum radios do this durring binding the radio.
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 10-21-2013, 05:52 PM   #693
mblgjr's Avatar
Trader Rating: 86 (100%+)
Anyone have a flow team that can't repeatedly find neutral? I have not installed new fw yet.
I've trained it twice. My trim is 0, subtrim is 0, I even turned off my throttle trim switch completely. I'm using my 4pk-s and 614 receiver. Never had issues with multiple other escs/servos. Only this Lrp.
I turned on ans saw that it wasn't neutralled before a run. So I trimmed it forward. Then when I pulled the car off the track, it was like it had decided the original neutral point was correct and the forward trim was providing forward drive (as it should have been), but it wasnt when I went out. It was showing to be trimmed forward to achieve neutral.
Any suggestions?
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 10-21-2013, 08:30 PM   #694
defcone's Avatar
Trader Rating: 15 (100%+)
Any suggestions?
Reset VR on radio.
defcone is offline   Reply With Quote
Old 10-22-2013, 08:40 AM   #695
ahpeq_ong's Avatar
Hey guys,
Can i have basic setup for 35meter straight with mid traction and tactical track.
Lrp Flow pair with reedy 13.5t.
Thank you.
Sponsor by : Visa, Mastercard, Paypal
ahpeq_ong is offline   Reply With Quote
Old 10-22-2013, 11:09 AM   #696
Tech Legend
Wild Cherry's Avatar
Tried to upgrade the firmware on my Flow last night .
Will accept 5.0 with no problems .
When I tried to load the 3.3 , the ESC accepts the down load & lets me reset the throttle. Blue lite comes on but no power to the motor ..
Tried four or 5 times and fails to accept the 3.3 ..
Does anyone have a idea why my FLOW won't accept the upgrade 3.3 firmware ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 10-22-2013, 12:53 PM   #697
JDJamminX1's Avatar
Check the following.
1. when updating the firmware, make sure that the battery is unplugged, and the on/off switch is in the off position.
2. After the update, you will need to do a factory reset. with the ESC off hold the set button and then turn on ESC. there wont be any indicator if you did this since the reset is instant.
3. Sometimes the USB port gets loose. check for connection or use different port on computer.
After that you should be able to program and calibrate.
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 10-22-2013, 01:05 PM   #698
Cridd's Avatar
Trader Rating: 16 (100%+)
I went from 5.0 to 3.3, just needed to recalibrate and was good to go.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 10-23-2013, 11:29 PM   #699
Tech Legend
Tried it 5 times and did each step as you suggest ,
even switched sensor cable for new .
Programs just fine on the 5.0
Now have to use the 5.0 because the 1.3 is no more & 3.3 won't load .
George W. Cherry
Old 10-24-2013, 10:08 AM   #700
JDJamminX1's Avatar
What does your computer tell you when you are trying to install the firmware? is there any warning windows or error codes that pop up?
Old 10-24-2013, 12:32 PM   #701
Logi Maker's Avatar
Trader Rating: 49 (100%+)
What's the benefit of the 3.3 opposed to the 5.0? Going to run a FLOW in Stock TC..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-24-2013, 01:09 PM   #702
Tech Legend
No error messages from the computer , after competed ESC displays the blue light .
When you give it throttle nothing happens .
Load the 5.0 and everything performs as it should ...
George W. Cherry
Old 10-24-2013, 01:16 PM   #703
Cridd's Avatar
try deleting your 3.3 file and getting a new one, maybe that file got corrupted. New file with new install.
Chris
B6D / T5M / SC5M
Old 10-24-2013, 02:02 PM   #704
JDJamminX1's Avatar
You also did the factory reset after install? Is the blue light solid or flashing. and did you recalibrate your EPA after install for both software's?
Old 10-24-2013, 04:16 PM   #705
Logi Maker's Avatar
Any way to tell what software is installed without hooking up to computer?
Kyle Predmore
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
