Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree3Likes
Old 09-02-2013, 09:13 AM   #661
Originally Posted by silden View Post
Yes this is in the same folder as the Firmware upgrade file.
When I go to www.lrp.cc, I find the file but it is without the warning on the top right of the page...
mhavlena is offline   Reply With Quote
Old 09-10-2013, 08:59 AM   #662
Originally Posted by Mornedn View Post
+1 for v5 firmware
anyone??
Mornedn is offline   Reply With Quote
Old 09-11-2013, 10:11 AM   #663
Originally Posted by Jochim_18 View Post
Adjusting power profile gives your more punch but you will get wheel spin.. Get the Revtech Killshot with LRP flow it's a killer combo...
Hi there.
Have you got a good starting point for 17.5 KillShot boosted. The straight will be +/- 30m. Any help will be appreciated
Gerrie is offline   Reply With Quote
Old 09-11-2013, 11:05 AM   #664
Originally Posted by Gerrie View Post
Hi guys
We are having our national event next week. Testing my Flow with x20 in 17.5 boosted, it looked like my turbo never activated. Here are the settings I ran. 0.5.5.8.8.5.0 with 30 deg motor insert. Was I "over timing" the motor ? Please give your suggestions please.
Yokomo BD7 fdr 6.6 . The car was strong out of the corners but that was it.
Gerrie. Were you able to sort this out?
What settings did you end up with?
HannK is offline   Reply With Quote
Old 09-11-2013, 11:32 AM   #665
Nope. I tried going up, down, different fdr, but ended up running my orca with D3.5. I will start testing again in a weeks time. I ended with 0,3,3,4,6,5,1 but did not get the pace needed especially for a national event.
Old 09-11-2013, 01:26 PM   #666
Thx Gerrie. Sorry to hear that. Please keep us in the loop
Old 09-19-2013, 02:06 PM   #667
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Exclamation Voltage Booster??......
Anyone out there run the Flow in 1/12 scale without the Voltage Booster??...... They say it has a booster in it for 1C applications but I heard of other drivers still using one...... Just wondering.....
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-19-2013, 02:56 PM   #668
Trader Rating: 15 (100%+)
Thanks!
The Flow does not have the bec for 1s, so I am not sure where you heard that? I run the Flow with a lipo rx pack.
EDIT2: Ok, I found the posts I was originally thinking of. Look at posts 60-70 of this thread and you will see a back-and-forth about needing a rx pack with the Flow.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 09-19-2013, 03:23 PM   #669
Kwikvdub's Avatar
This is what I read for the info on it:
Technical Data of Flow WorksTeam ESC:
Case size: 32 x 34 x 21mm
Voltage input: 3.7 - 7.4v
BEC: 6.0V / 3.0A
Sensored brushless system: YES
Forward/Brake: YES
Multi mode profile adjustment: YES
Multi Protection System 2: YES
Internal Temp Check System 3: YES
Power wires: 3.3mm
Recommended motor limit: 3.5T
Rated current: 400A/phase
Typical voltage drop: At 20a - 0.011V/Phase
Weight: (excl. wires) 40g
Plugged fan: Yes
I thought the BEC put out 6.0V at 3.7 to 7.4V....
I guess I need one...... Just confused with the stats of it....
Alex Valdes
Old 09-19-2013, 04:06 PM   #670
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Default lrp sxx v2
well once again I am sending my speedo back to lrp this time it is the sxx v2. it just shut down after a qual. Ran the speedo for 3 week with out a hiccup and now this. I would like to add that my flow is still working strong after I got it back from lrp and my sxx stock spec in my 1/12 has not had a issue yet after one season of running.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 09-19-2013, 05:01 PM   #671
Kwikvdub's Avatar
Hey Juwan, do you run a receiver pack or booster??..... Thanks!
Alex Valdes
Old 09-19-2013, 05:17 PM   #672
the lrp sxx stock spec don't need a booster pack. that is one of the main reason I switch to it. I am sure that you need a booster pack with the flow.
Old 09-19-2013, 05:31 PM   #673
Kwikvdub's Avatar
Thumbs up
Hmmmmm..... I have both...... Thanks for the info..... See you at the track real soon!
Alex Valdes
Old 09-19-2013, 05:52 PM   #674
Team Speedy's Avatar
Trader Rating: 42 (100%+)
True, however this only implies if your running on the original board that could handle 3.7-7.4V. If you have the updated board, (Stock+Mod) then your forced to use a booster or receiver pack. The logic board found on the Stock+Mod has an updated BEC which does not support single cell operation due to the voltage input required to properly operate the unit. Most importantly, the Flow requires an external source of power, I.e a booster or receiver pack (Life or Lipo) to operate, partly due to having a similar voltage constraint as found within the Stock+Mod logic board.
Team Speedy is offline   Reply With Quote
Old 09-19-2013, 08:22 PM   #675
Nuno Gancho's Avatar
Hi, anyone tested a flow with a fanton d3.5 13 5 turn boost setting and gear thanks
Nuno Gancho is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 08:03 AM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 12:35 PM
LRP SXX StockSpec ESC Stein Tumert Electric On-Road 1241 06-08-2012 08:52 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 12:24 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
